OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
Ol' school for sure.... In this field, 5-10 years is like ancient history
Difference between KW CSLPM1.TG and KW CULPM1.TG?
Considering the Convoy Z1, which offers KW CSLPM1.TG 6amps or KW CULPM1.TG 8amps
They use the same die but different package. CSLPM1.TG has worse thermals, that’s why Convoy choose to run it with 2 amps less.
Overall CULPM1.TG will be brighter but hotter.
Is the CULPM1.TG better if run at the same amps? Any reason to chose CSLPM1.TG over CULPM1.TG?
How do both compare to SST40/20?
I used the CSLPM1 with the stock 6amp driver and it’s awesome. Had 4x SST40’s die instantly in an order of Z1’s so I installed these.
SST40 in a C8+ maxes out at 642m, the CULPM1 maxes out at 1002m.
SST40 = more lumens with a wider beam
Osram leds = higher intensity with a narrow beam
No idea. The culpm1 hasn’t been officially tested by anyone to compare the data between the two
Assuming equivalent bins, at low currents they would be the same. Once heat starts playing role, CULPM1.TG will be better but up to 6A the difference would be very low.
Have you been able to compare it to a Z1 with KW CULPM1.TG?
Interesting, I will have to find some beamshots to compare how narrow the two are
This is the CSLNM1 which is slightly narrower but you’ll get an idea
Not so slightly. 2mm² Osrams should be almost half way between CSLNM1 and XP-L HI and actually a little closer to XP-L HI. And in Z1 they have a rectangular beam.
I take video demos for all my customers so here’s comparisons for the CSLNM1, CULPM1, XPL HI, SST40 all in the Convoy C8+
Where can I find the video demos?
I know the Z1 has a unique beam based on other videos I’ve seen but I’m still interested in these emitters for different lights
The Osram videos are titled as Osram C8+ V1 & V2, to stop customers jumping on AliExpress bypassing me.
The V2 runs on a fet driver so Convoy won’t sell it under warranty
I just saw this light today. Searched BLF and there are only two mentions of it sitewide. I agree PM1 maybe makes more sense, but it still maybe the most desirable Lumintop in recent times… except it looks like a FET driver. Wonder how that’s gonna work out
EDIT: Also, hold for off UI. Well they sure do know how to eff something up don’t they.
The X1L has 8 AMCs and no FET. For whatever reason they were unable to just modify the FW21 driver accordingly and still run Anduril, and the X1L uses a different MCU that isn’t as easily reflashable.
I put a FW21 Pro driver in mine and flashed it with Anduril, using the 219C config. Much better that way, and the LED seems to handle it very well. You can get the driver from Lumintop’s AliExpress store for 8 USD.
Good pic, not sure “slightly” is the correct phrase. That Osram LED looks useless for anything other than a laser pointer!
Great info. Thanks! Wish they could get it right the first time, though.
With the FW series the only thing lumintop is getting right is their checkbooks.
