OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1403 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 21 min 25 sec ago
supreme wrote:
Agro wrote:
They use the same die but different package. CSLPM1.TG has worse thermals, that’s why Convoy choose to run it with 2 amps less. Overall CULPM1.TG will be brighter but hotter.
Is the CULPM1.TG better if run at the same amps? Any reason to chose CSLPM1.TG over CULPM1.TG?
How do both compare to SST40/20?
SST40 in a C8+ maxes out at 642m, the CULPM1 maxes out at 1002m.
SST40 = more lumens with a wider beam
Osram leds = higher intensity with a narrow beam
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Funtastic
Funtastic's picture
No idea. The culpm1 hasn’t been officially tested by anyone to compare the data between the two
Agro
Agro's picture
Last seen: 3 weeks 3 days ago
Assuming equivalent bins, at low currents they would be the same. Once heat starts playing role, CULPM1.TG will be better but up to 6A the difference would be very low.
supreme
Last seen: 1 week 4 days ago
Funtastic wrote:
supreme wrote:
Difference between KW CSLPM1.TG and KW CULPM1.TG?
Considering the Convoy Z1, which offers KW CSLPM1.TG 6amps or KW CULPM1.TG 8amps
I used the CSLPM1 with the stock 6amp driver and it’s awesome. Had 4x SST40’s die instantly in an order of Z1’s so I installed these.
Have you been able to compare it to a Z1 with KW CULPM1.TG?
supreme
Interesting, I will have to find some beamshots to compare how narrow the two are
Funtastic
Funtastic's picture
This is the CSLNM1 which is slightly narrower but you’ll get an idea
Agro
Agro's picture
Not so slightly. 2mm² Osrams should be almost half way between CSLNM1 and XP-L HI and actually a little closer to XP-L HI. And in Z1 they have a rectangular beam.
Funtastic
Funtastic's picture
I take video demos for all my customers so here’s comparisons for the CSLNM1, CULPM1, XPL HI, SST40 all in the Convoy C8+
supreme
!{width:60%}[img]https://i.imgur.com/FRWUGfV.png[/img]!
Where can I find the video demos?
I know the Z1 has a unique beam based on other videos I’ve seen but I’m still interested in these emitters for different lights
Funtastic
Funtastic's picture
https://youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w
The Osram videos are titled as Osram C8+ V1 & V2, to stop customers jumping on AliExpress bypassing me.
The V2 runs on a fet driver so Convoy won’t sell it under warranty
JaredM
JaredM's picture
Last seen: 25 min 37 sec ago
hodor wrote:
Gotta say I’m kinda tempted by the Lumintop X1L . CSLPM1 / CULPM1 would be better though IMO.
I just saw this light today. Searched BLF and there are only two mentions of it sitewide. I agree PM1 maybe makes more sense, but it still maybe the most desirable Lumintop in recent times… except it looks like a FET driver. Wonder how that’s gonna work out
EDIT: Also, hold for off UI. Well they sure do know how to eff something up don’t they.
uselessuser
Last seen: 9 hours 16 min ago
The X1L has 8 AMCs and no FET. For whatever reason they were unable to just modify the FW21 driver accordingly and still run Anduril, and the X1L uses a different MCU that isn’t as easily reflashable.
I put a FW21 Pro driver in mine and flashed it with Anduril, using the 219C config. Much better that way, and the LED seems to handle it very well. You can get the driver from Lumintop’s AliExpress store for 8 USD.
Chicken Drumstick
Last seen: 6 months 1 week ago
!{width:60%}[img]https://i.imgur.com/Vy2XFqk.jpg[/img]!
Good pic, not sure “slightly” is the correct phrase. That Osram LED looks useless for anything other than a laser pointer!
JaredM
JaredM's picture
Great info. Thanks! Wish they could get it right the first time, though.
Scallywag
Scallywag's picture
Last seen: 3 days 11 hours ago
With the FW series the only thing lumintop is getting right is their checkbooks.
JaredM
JaredM's picture
Ordered some new HHL532.TK tonight. Will compare to the CSLNM1 in a Jacob A60 when they arrive
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 week 2 days ago
Jacob A60 Smile ! OMG! Thumbs Up
kramer5150
kramer5150's picture
Last seen: 2 months 5 days ago
Jacob A60… Wow some BLF history right there.
Isn’t its reflector designed for an XRE?
JaredM
JaredM's picture
Yes. It’s one of the last one’s available. It’s the Jing Ge or whatever version. Deep plastic reflector that’s very, very picky and honestly not giving the cd/mm it should. Based on frontal area, I’d expect around 300kcd. I think it’s more a reflectivity issue rather than geometry, but that’s pure speculation. I love the look and feel in hand of it though (not to mention the nostalgia). I love the aggressive knurling and the fat tailcap (which I’ve modded with a forward clicky). To focus properly it needs to have the spacer close to 2mm thick, so some non insignificant number of lumens escape to the sides. I’ve gotten a ringless beam from it though. Tight spot. Clean but large corona. Zero spill artifacts.
ArturoSC1
Last seen: 1 day 6 hours ago
Yesterday I was adjusting the cslnm1 led of a Convoy S2 + that I bought a short time ago, since it was not well centered and also the height of the led with respect to the reflector was not correct. The change is impressive, the spot is now practically half and much more intense. Comparing and measuring the S2 + w1 now has more range than the M21C xhp70.2
kramer5150
Curious… just how fragile / delicate is the CSLNM1.TG ?
I have some older IMR26650 (orange powerizer, battery junction) cells about 3.5 years old. I have never abused them, never over charged / discharged or anything like that. I have always used them in applications less than 1C. Do you think I can FET direct drive a CSLNM1.TG in a large 26650 host like a convoy L2 with older IMR cells? It would be for short 30 second bursts only. I would not use it as a constant-ON scenario.
Yokiamy
Yokiamy's picture
Last seen: 23 hours 17 min ago
Depends on the current output, the cslnm1 doesnt like currents over 5A.
4,5A to 5A max!
Tom E
Tom E's picture
Last seen: 6 hours 44 min ago
So for example, you can limit voltage/amps by using thin long LED wires. The battery is only one part of the circuit.
The old powerizer batteries were pretty good, not weak at all. I still have a couple. The W1's are pretty low voltage so doesn't take much to hit 5+ amps.
JaredM
JaredM's picture
Seems like there might be a new throw king in town, and it’s DD compatible Evil
Tom E
Tom E's picture
So are you think'n it's got better throw because the surface area is the same or smaller?
What are you using for a MCPCB?
Scallywag
Scallywag's picture
What’s the surface area? The CULNM1 was hitting about the same lumens IIRC – and possibly higher, if I’m remembering right that someone besides L4P found a slightly higher bin
Superstocker
Superstocker's picture
Last seen: 4 hours 57 min ago
1.06mm^2 it looks like it might fit on regular xp mcpcb’s. I’m not sure about that though.
JaredM, thank you so much for sharing that data!
JaredM
JaredM's picture
I need to point out that my ‘lumen’ calibration is far from concrete. I cross referenced a bunch of emitters to maukkas readings as well as a few other prominent testers and it seems within a reasonable margin of alignment. Relative values I have a high level of confidence in though.
The Boost HL aka CULNM1 may still be the king, and it has the major advantage of having a neutral thermal pad, but Osram has killed that model and I’ve never been able to source one that doesn’t come with a flashlight.. These are cheap at Mouser and perform very well it seems. Centering can be done with a twisted square XM gasket or a slightly reamed circular XP one. I successfully reflowed it to an XP Noctigon the first try. Luck? Idk, not testing it lol.
For sure it’s going to be the best option for FET drivers.
JaredM
JaredM's picture
With a Convoy 5A linear driver and near fully charged LG H26 (4.11V) I saw 272kcd with the HHL. Same setup went for ~237kcd on it’s best day (229kcd most recently) with the WF1. I’ve put the cell on charge and will try it DD next. Guessing I’ll see around 5A that way. Maybe I’ll squeak past 280 Wink
Agro
Agro's picture
Nice!
