Bump! I’m still hoping to see if anyone knows the answer before I place my order.
Given that there are some drivers out there that require the ring to be modified, I’m sure I’m not the only one who has asked about spare retaining rings for the S2+.
That ring does not fit the S2 or S2+ because they are made for 17mm drivers. That retaining ring/adapter is for larger hole pills (20mm) to make a 17mm driver to fit there. Withouh that, the pill will be suitable for 20mm drivers.
In case you need a retaining ring for a S2/S2+ pill, maybe you can ask Simon directly, I’m sure he’ll send you one
Thanks. That was how I thought the dimensions were meant to be interpreted, but wasn’t quite sure, and I didn’t know Simon takes off-menu requests. I’ll be placing my order tonight.
Just revieved a half dozen holsters and my first convoy tube light- the s21b with xhp50 5000k, everything is fantastic!
Thank you Simon! Quick shipping and flawless products.
Never knew what I was missing with this simple little light! Fantastic size and functions great, beam is awesome.
What could make it better you say? When your KR4 pocket clips PERFECTLY fits on your convoy s21b, that’s what! Can’t wait for my new batch of kr4 deep carry clips to come in now.
And you still have a working flashlight? The electrical path was not disconnected installing clip?
[/quote]
I “extended” the connection using a length of 18 gauge copper wire - same thickness as the clip “band”- bent into a circle the same size as the contact point in the tail cap (outer ring). Takes a couple tries of trimming and refitting and flattening.
Did the same thing on my d4v2 to install the fw3a clip a week or two ago. They both have been working well. Please don’t tell me this is a terrible idea… :cry:
yea i have seen tis one on AX before, but when looking into it more i don’t like having the exposed nut holding the screws on. Would definitely work though, and with some locktite (superglue) would probably never come off on its own
