If I’m lucky I get 5-6 hours sleep, but usually this is broken. At worse 0 hours, even with co-codamol. I can be in pain all day and as long as I’m busy it doesn’t bother me, but as soon as I try to sleep its there.
Seriously? It’s the most common anti-histamine there is. On the shelf of just about every store, in one brand or another. For allergies, motion-sickness, and sleep. I live in a nanny state too, but I hope it doesn’t get that bad.
Then again, there is other stuff I have to order from the US, because we can’t get it here any more. Try Ebay to see if you can get it that way.
When you describe brain fog and say you slept 8 hours and it didn’t feel restful, it makes me think you have sleep apnea. There are two forms of sleep apnea, one is obstructive (throat issue) and the other is central (brain issue). You should ask your doctor for a sleep study.
What you’re describing to me sounds like classical melatonin brain-fog, unrestful sleep, headache the day after.
Always start with the smallest dose that’ll put you under. DO NOT take a second (or more) dose if you wake up, or if you miss that chance to sleep, eg, by trying to stay up past when it hits. Else what happens after is exactly what you describe.
Think of a starter’s gun in a race. He shoots it to start the race, and that’s it. He doesn’t keep shooting, reloading, and shooting some more, once everyone’s running on the track, let alone after everyone crosses the finish-line.
That’s all you need, to get to sleep. It resets your body’s clock to say, “Okay, sleep now”, and that’s it. One and done. Hit it and quit it.
That’s why I said melatonin puts you under, and NicOH (or NicNH2, etc.) keeps you under. Melatonin is not a sleeping pill. It’s only that starter’s gun that indicates, “Ready… set… sleep!”.
Frankly, I think it’s misusing or at least misunderstanding melatonin that gives it a bad rep. “Doesn’t work for me”, “Gives me a headache the day after”, etc. And that “time-released melatonin” should be outright banned, ’cause that’s not what it’s for.
Oh yeh, I was gonna add… look into “non-24”. If your “24hr cycle”, well, isn’t, then you might naturally want or need, say, a 31hr cycle. So you can’t fall asleep early enough, force yourself to wake up “early”, then almost collapse from lack of sleep at inopportune times, etc.
That’s almost exactly what I told my doctor when he recommended a sleep study. I said I have had sleeping issues my whole life, from back when I was a kid and long before my weight was not ideal. I knew my weight issues was because of the sleep issue… A poor night’s sleep just makes me less active and need to snack more.
Statistically, 1 in 4 people have sleep apnea. It’s more common that I ever realized.
Whatever melatonin is supposed to do, it has zero effect on me. No sleepiness, no side-effects, nothing the next day. I’ve tried it many, many times, using different dosages and taking it at different times. The only thing it might do, is give me a slight headache if I take 10mg of it.
btw, that too is classic sleep apnea. The sweating is a hint to the suffocation that woke you up, but you won’t recall it. The dreams are your body attempting process the experience in a way that keeps you asleep, but it ultimately fails and you wake up sweating.
I do understand wanting to experiment on your own… One more thing you might try is a bottle of generic Flonase from Walmart. Take a few hits an hour before bed, and if you wake up more refreshed than usual, great. If not, it was cheap.
I’ve never heard of xylometazoline until now. Side effects include trouble sleeping, headache, etc. Probably not a good diagnostic tool since the side effects are similar to the issues you are trying to reduce. It’s also not recommended for more than 7 days use.
