Window in Garage was broken over night, snow entered through said window. Did not find out about the window until the next morning. Chargers were sitting on a work table. Yeah I know never leave things charging unattended.
That’s probably true… but I still see some formerly “Miboxer” chargers being sold online, like in Banggood, and also a few other online sources…
Provided the charger works as intended and doesn’t malfunction prematurely (and not really mind about possible warranty issues — since it seems the “Miboxer” is not around anymore, I feel that they’re still good to use).
I suppose if longer warranty is important, then may have to cross out Miboxer chargers… (I got Miboxer charger from BG before and they did address issues that I encountered with the charger, if problems occured within a few days after receiving and using the charger)…
If you find the need for a smaller, 2-slot charger, I got a Littokala Lii-S2 for $13.50 a while back and honestly it charges my Li-ion cells better than my “new version” i4 Intellicharger or my DLYFULL T5 Test Charger.
The Lii-S2 holds my unprotected 21700s just fine, and has user-selectable charge current, and will charge NiMH, Ni-Cd and even LiFePO4 with user selection of voltage. Charging isn’t the fastest, but it will do a single cell at 2 amp.
I just wish it was USB-C input instead of Micro.
My cells often come off the other chargers at 4.15 to 4.17 V, but the Liitokala seems get them to 4.18 to 4.20 much more reliably.
Really glad I got it and more packable than the bigger chargers.
I’m already hip-deep in my Opi, almighty Miboxers, Zanflares, Nitecores, from back when I was trying to find The Charger™, and GB and others were having hella good discounts like every week.
I just popped in here to see if there was any blazing new tek that might be of interest.
Is there anything "better" than Vapcell's S4+ charger right now? The only device that matches or even surpasses the S4+ charger in terms of reasonable features is the SkyRC MC3000. Unfortunately, it barely accepts unprotected 21700 batteries that have to be squeezed into the slots. So far, SkyRC does not seem to be interested in upgrading this model or in launching a successor.
Then there's the Miboxer C4-12 which has less features than Vapcell's S4+ but offers perfect voltage termination at 4.19V - 4.21V. I cannot tell at what voltage the S4+ settles batteries yet but I hope it's closer to 4.20V than most of my other devices that leave batteries finished with a resting voltage of 4.12V - 4.17V. Too sad that Miboxer has stopped selling chargers.
Then there's the BLF charger project by BlueSwordM. As much as I am looking forward to seeing this charger come to life, I doubt it is going to happen anytime soon.
I’m in the market for a new 4 bay charger too. Protected 21700 capability is a must.
So far, it looks like nothing fits the bill as well as the Vapecell S4+.
What about Nitecore’s offerings?
This kind of sucks because there are VERY few chargers that can do what the C4-12 can do.
3Ax4 slots with 4x26650 and 21700 support. I also like having all of the different current options it has.
Heck I’m looking for a backup with those features and would be happy to find a decent one that does 2A on all slots for around the same price.
VC8 seems Ok, but needs an additional QC PS. Also HKJ gave it a meh rating.
Vapcell S4 also had some issues in his testing as well, but was somewhat solid.
Maybe multiple Xtar SV2s, but then I’d have to deal with multiple wall warts and tight fitting 21700s
c) SkyRC MC3000 = supports 4x26650 and 4x unprotected 21700 (unprotected 21700 are a "tight fit" for the MC3000 though ; won't fit protected 21700)
d) Vapcell S4 Plus = supports 2x26650+2x21700 or 4x protected 21700 (the 2 inner slots won't fit 26650 when the 2 outer slots are occupied with 26650 batteries)
e) Liitokala Lii-600 = supports 4x 26650 and 4x unprotected 21700 (won't fit protected 21700)
I couldn't agree more with you. I do have a couple of chargers here, among them the C4-12 V1, C4 V3, C2-4000, SkyRC MC3000 and Vapcell's S4 Plus. They all have their pros and cons. Maybe I can find the time to discuss some ideas with Vapcell in order to see an improved and enhanced S4 Plus model in the future. For instance, I miss the storage or LiFePO4 charging function to level my batteries at 3.6 - 3.7V.
I didn’t even know this was a thing until I stumbled across someone on reddit who mentioned it. I’ve been just watching the charger and charging at low current to do storage. This makes it SO much easier.
I noticed in a few of the reviews (HKJ’s review thread), the Vapcell S4+ is a little bit buggy? Has there been any firmware improvements since? I’m torn between the Lii602, the Dragon VP4, and the Vapcell S4+
Vapcell S4+ has (from what I know), the earlier version and later version with some fixes. But it seems (based on reports), that they may have some issues, more specifically regarding the charging portion when doing a capacity test of NiMh batteries. But for other basic functions (eg. regular charging, capacity test for Li-Ion batteries), the (old & new) Vapcell S4+ seems good.
Liitokala Lii-600 still need more in-depth test review by people who can do in-depth testing (like HKJ)… I’ve tried out the Lii-600 and it appears to work good (it doesn’t seem to “overcharge” (not that much) unlike the Lii-500S where reports are that the Lii-500S tends to charge to 4.23-4.25v. On the Lii-600 I tested, it appears to just charge to 4.20-4.22v which is a very good result, but then that’s only 1 sample…) I haven’t tested much charging / doing capacity test with the Lii-600 so I can’t comment too much with this unit yet.
Xtar Dragon VP4 is an older model but charges very well, both Li-Ion & NiMh batteries. It doesn’t have as much informative display (I usually like to see voltage instead of percentage charged) and is a reliable charger. It’s also a bit more expensive.
I probably would pick the Vapcell S4+ given the 3 choices you mentioned… if you charge/test mostly Li-Ion batteries.
If you have more bigger batteries and “D” size NiMh, then the Xtar Dragon VP4 is the only charger that can fit 4x “D”-size NiMh at the same time (it’s the widest charger I’ve encountered in terms of individual width per slot…) Charging current is not too high (compared to the other chargers), but should be good enough unless often need to charge higher-capacity cells (eg. 21700/26650) more quickly…
Thanks, I’m awaiting more reviews of the liitokala. I do a mix of nimh aa/aaa and li ions. Lots of almost perfect options…(example: xtar vc4s would be great, except it occasionally charges aaas at 2 amps)
Might be worth a shot to snag a 2 button version Miiboxer C4-12 while they’re still around. HKJ rated it quite well and it does multi chemistry well too. Only thing I don’t like or use on mine is the auto current selection which can easily be overridden. It also uses a 12v 5a laptop style power supply.
