Is that to be expected from a $10 flashlight? Or there are no boost drivers with >90% efficiency in 0.8-1.8 Vin range regardless of how much the light costs?
Thinking way back, my Walkman was able to suck two AAs dry in the late 80s, so it should be possible. Maybe not in a flashlight form-factor?
It’s all about the power draw. That’s just a lot of power to ask of a AAA alkaline. If the output were lowered a bit (like in my 42 lumen test), I imagine the alkaline would respond much better.
edc01 (new worm), is a 3 mode light, arguably more versatile, and batteries can last longer
The E3a comes on at a brightness, 90 lumens, that drains an AAA in 30 minutes… to me, that is a waste… but its the smallest, lightest, highest CRI aaa option, if someone wants a keyring light for example. I personally choose not enlarge my keyring. My lights are easier for my use, separate from my keys.
the edc01 is rated to go 4 hours on its medium of 30 lumens, plus it has a 5 lumen low, plus a high that matches the E3a… however, there is NO High CRI edc01 option.
to get High CRI aaa, another option is the aaa Tool from drop.com… comes in fancy metal too… $lippery
so, for simplicity, the tiny E3a, with high CRI, is king of the little light Hill
Runtime on these is impressive! I’m flummoxed that the new Skilhunt E2A AA can’t keep up despite more capacity and larger host. Zeroair’s review shows the E2A is stabilized at only about 65 lumens.
Thanks gchart for these very interesting runtime graphs.
I wonder how a primary lithium would behave: if any of the "super-reviewers" has one at hand, I'd like to see it too on a graph.
I have bought a couple of E3A as gifts (and will buy more when I find a super deal), and plan to include a primary lithium in the gift, for people who don't have rechargeables and a charger.
OTOH, here are the result of a few attempts to improve the beam, since I didn't like the beam irregularities from the stock pebbled optic (though only visible in "white-wall hunting"). I've tried the following lenses from Yajiamei Store:
Smooth lenses:
20°: strong color shift
45°: OK but strange beam shape, slightly squared
90°: very visible central dark spot
Frosted lenses (they call them "Shamian"):
20°, 30° and 60°: all OK, no color shift, very smooth transition between central area and spill. I'll probably stick to 20 or 30 degrees, not much difference between both anyway.
90°: central area is darker and more purple.
In conclusion, if you like smooth beams without significant color shift, do your E3A a favor by replacing its pebbled lens with a 20-30° Shamian one, or 60° if you like a more "wall of light" beam.
Unfortunately I was not able to take nice beamshots like some of you do, my attempts did not do justice to the beam improvement, but my eyes do see the difference.
Emitter efficiency is probably part of it. The E3A he tested was neutral white, but not high CRI. The E2A is 95 CRI. That should cost it around 30% efficiency.
It’s more than that, though. Zeroair’s graph for the E2A shows about 50 lumens/W on medium and 63 lumens/W on high.
His E3A graph works out to around 120 lumens/W.
Even considering the SST-20’s are not the most efficient emitter around, I would have expected them to be able to achieve over 80 lumens per W on high with a comparable driver. And a stepdown should not be needed at all on the E2A when running on AA batteries. It seems to use the same logic as with 14500 batteries.
I have an E2A and am happy with it - the size and hand feel are great, and the optic they use makes a superb beam profile in my opinion. It’s not the light to get if you need maximum output or runtime, though. It’s a good light that would be great if they improve the driver.
What color temps are the various versions available on Skilhunt’s Amazon page? They don’t even say if netural or cool white. I ordered the high-CRI version as I’m sure that won’t annoy me. But if there’s a significant color or lumens difference I might need a second one! Right?
