Sofirn BLF LT1 Lantern, 5” Rubber base
16 posts / 0 new
mrmccormack
mrmccormack's picture
Last seen: 6 months 3 weeks ago
A nice sturdy base using a drill 5” sander rubber disk.
About $5.00 USD
Offers excellent stability especially outdoors.
—- Rob
Edited by: mrmccormack on 01/25/2021 - 15:16
Caleb
Caleb's picture
Last seen: 1 week 5 days ago
Great idea!
nobody
Last seen: 15 hours 27 min ago
Nice!
mrmccormack
  • Thank you for the comments
  • I’ve kept the disc on for the last couple days and it is really nice, it is the perfect size
  • It gives the lantern a whole new feel, and the rubber protects any surfaces from scratching
  • certainly one of my favourite accessories
—- Rob
Phlogiston
Phlogiston's picture
Last seen: 2 weeks 1 day ago
Excellent idea!
Does it come with the right bolt for the tripod mount, or did you add that separately?
mrmccormack
Phlogiston wrote:
Excellent idea!
ANSWER:
  • No, I added a shorter 1/4” bolt with a flat head and reused the special washer provided. .
  • These bolts are readily available at any hardware store (Flat Head Square Drive Stove Bolts) and can be easily cut to length with a hacksaw. Only flat head bolts will work.
  • The bolt it comes with may be too long and might have a finer thread.
  • 1/4×20 it’s what you want for camera equipment.
Hope that helps, thank you for your comment.
—- Rob
Zappaman
Zappaman's picture
Last seen: 3 months 4 days ago
Rob, Sofirn should send you a free light. You ARE the LT1 dude!
I bought a VERY powerful neodymium magnet with an LT1 lantern from another member here last week. He found this magnet with very close to the same diameter as the LT1, a 1/4” hole already cut in it and about 3/16” thick. I cut down a cap screw to fit the magnet’s hole (beveled on one side for a countersink). It came out really nice! But it is SO strong it would easily scratch a lot of nicer metal surfaces I’d place it on.
After looking over your pics above, I started thinking I might be able to get this magnet under a rubber disk similar to yours above. I love your ingenuity using a simple rubber part that will probably last for 50 years here! I think I found some that are flat enough on top, but have some recess underneath where this magnet from hell might fit under the rubber disk, and so be flush with the magnet (maybe with some razor work for a good fit). Then try with felt or something on the bottom. This way the magnet can’t scratch surfaces.
So if I can pull this off, I’d have a lantern that won’t fall over, and that sticks to metal without scratching it. I’ll post my results here.
I also asked the BLFer I got this magnet from where he got it. He sent a link to Amazon to a $30 magnet, but hinted he got his out of China. Anyway, as you are doing all these great mods I thought I’d mention the magnet idea and thank you for THIS idea! Thumbs Up
ZappaMan
mrmccormack
ZappaMan
Hey thanks for reply and kind words.
If you could combine the 5” disk with a magnet that would be cool.
I posted the rubber coated magnetic disk I have in my case here:
https://budgetlightforum.com/node/76309
Favourite carrying case with accessories and magnetic base
Reference
  • Amazon $14 USD
https://www.amazon.ca/Sabrent-Rubber-Coated-Magnetic-Cameras-CS-MG88/dp/B081BFQ7NN?th=1
I got the 66mm diameter version.
Seems just the right strength, not too strong to damage, rubber coated is excellent – should last forever. I wonder if the 88mm version would be better?
I am finding uses for the 360 degree, pivoting small ball head that was included.
I do keep the 5” rubber disk on most of the time… there something about it that just suits how I use the lantern.
Good luck with it all, thanks again
—- Rob
rost333
rost333's picture
Last seen: 18 hours 18 min ago
Different colours? No problem:
rost333
rost333's picture
mrmccormack
Thanks for your post, I was going to order a red one.
However I am not sure if the 1/4” x20 will fit into the sander, as they appear to be metric only.
I suppose they could be tapped to the standard tripod thread.
Maybe I’ll order one to try, the price is good.
—- Rob
Phlogiston
mrmccormack wrote:
Phlogiston wrote:
Excellent idea!
Thanks Rob, that’s very helpful Thumbs Up
Rexlion
Last seen: 17 hours 19 min ago
Nice rubber base! This accessory appeals to our base instincts… Big Smile
== We save the planet from darkness ==
Helios azimuth
Last seen: 1 day 5 min ago
Do you have a side view photo of the plain rubber base? Thanks
mrmccormack
Here is a Sideview with that when I’m extension to increase height.
—- Rob
DBSAR
DBSAR's picture
Last seen: 4 hours 24 min ago
Awesome idea! Big Smile its great to see fellow BLFers creating new accessories & idea for the LT1. Thumbs Up
