Oh I didn't see that mentioned on the site I visited ... do you know the length with the 18650 tube ?
Thanks for the suggestions roostre and Lightbringer.
MascaratumB: Penny wise but Lumen foolish:A for effort SerenityNow, but I’m looking for 18650 powered lights.
That light can be powered by 18350 or 18650s!
Oh I didn’t see that mentioned on the site I visited … do you know the length with the 18650 tube ?
This is the info from zeroair review:
The Manker E14 iii 18350 flashlight is a flashlight for all flood. As part of the muscle combo, it is more of an EDC type light. Read on for some testing, and thoughts!
Size and Comps
Size: 71.2mm (2.8″) length x 28mm (1.1″) head dia. x 25.8mm (1.01″) body dia.
I measure it as 72.24mm (long, 18350) x 28.05mm (head) x 25.79mm (body), and 100.31mm for the 18650 setup.
Weight: 82.8g (2.92oz) w/o battery, 109g (3.84oz) w/ battery
I weight it as the following: 42g (head), 38g (18350 body), 52g (18650 body).
Lightbringer:MH20, but 4.1”.
My edc, hasn’t been dethroned yet.
Is it stock? Swapped emitter atleast?
Rarely because it’s discontinued. I have the NW version, no need to swap the emitter.
For the Emisar d4v2 I would choose the e21a that comes with 6 Amp regulated driver. I would also consider the Skilhunt m200. A little longer than 4” but still very compact and can put a good amount off sustained lumens.
MH20, but 4.1”.
That’s a nice looking light.
Now I want one.
Does it?
Emisar D4V2 flashlights have become so popular they are currently branded as "the flashlight of r/flashlight." Despite this, I have only recently picked one up. I went for brass (of course) and the Nichia E21A emitter in 4500K temperature. Read on...
lfb:For the Emisar d4v2 I would choose the e21a that comes with 6 Amp regulated driver.
5A. My bad. But my point is it produces over 400lm sustained without pwm.
It doesn’t matter if it’s 5A or 6A - there’s no regulation on high mode, output falls off the cliff right after startup and it stabilizes on a measly ~450lm. I know it’s small but those are pretty weak numbers.
Exactly, 5 or 6A doesn’t make any difference. I don’t know many flashlights, so I thought that sustained 450lm for a light of that size and hi cri was good. Looks like a FET+7135 is less efficient.
Stock NW is about 4500K, no high CRI or anything (CRI is pretty low actually).
Nope, bone-stock.
Might be the “MH20W” but the ‘W’ isn’t etched anywhere on it. Wonderfully just-warm-of-neutral, guessing 4500K or so.
Got a coupla other MH20s as spares, but don’t recall if they’re NW or CW.
Yeh, I learned my lesson. Get something, like it a lot, want spares so you don’t have to be without one… GET spares before they get discontinued.
Kewl, so I guessed right. :laughing:
phantom23:Rarely because it’s discontinued.
Wanna reinforce the stock?
Different stores with different prices :nerd_face:
https://www.aliexpress.com/item/4000437761970.html
https://www.aliexpress.com/item/32850138365.html
https://www.aliexpress.com/item/4000752191403.html
My EDC, nice light, neutral tint, plenty of lumens, Anduril, quality battery and USB charging if that matters.
Thanks Blazer, I have an SC31 Pro, great light, but I'm looking for options 4 inches or less.
I have a Folomov 18650s and a DQG Tiny 18650 inbound, excited to try them out.
Au contraire! My E14III with the 18650 tube is under 4 inches
Also, my Lumintop HL3A has to be one of the shortest 18650 lights ever made!
Penny wise but Lumen foolish:A for effort SerenityNow, but I'm looking for 18650 powered lights.
Au contraire! My E14III with the 18650 tube is under 4 inches Also, my Lumintop HL3A has to be one of the shortest 18650 lights ever made!
Yes someone pointed out my error above, I didn't see an 18650 extension tube mentioned when I looked at the light... thanks for the suggestion!
Yes someone pointed out my error above, I didn’t see an 18650 extension tube mentioned when I looked at the light… thanks for the suggestion!
Yes I did, and then I posted this:
Manker E14 III 18350 Quad Emitter Flood Flashlight - ZeroAir ReviewsSize and Comps
