And you still have a working flashlight? The electrical path was not disconnected installing clip?
[/quote]
I “extended” the connection using a length of 18 gauge copper wire - same thickness as the clip “band”- bent into a circle the same size as the contact point in the tail cap (outer ring). Takes a couple tries of trimming and refitting and flattening.
Did the same thing on my d4v2 to install the fw3a clip a week or two ago. They both have been working well. Please don’t tell me this is a terrible idea… :cry:
yea i have seen tis one on AX before, but when looking into it more i don’t like having the exposed nut holding the screws on. Would definitely work though, and with some locktite (superglue) would probably never come off on its own
When given the choice, I think its always best practice to select a –0.0020 DUV in the neutral whites (3750-5250K). In my opinion, when you go above or below this, returning to the BBL is fine.
SKV, I wasn’t so lucky with the 4000k fc40 sample that I received late 2020. I don’t have a way to measure, but I’d say its well over +0.0100. With two layers of eighth minus green AND Joshks paint, its still slightly green. Honestly the subjective color rendering before tint correction was easily worse than 80cri XPLHDs and even my 4000k MTG2. Saturation was terrible. Its okay now, but there’s angular tint shift due to the filters and output has dropped too much. Waiting on one from Simon now. Hope these truly are BBL.
if you think about raising driver current specifically for this host + led combination, I think, 3A would be the best setting (keeping in mind, that this host is smaller than L6 and L21A).
Anything change with the XHP35 to run at higher amps? From this old test here, it peaks at ~2.5 amps: https://budgetlightforum.com/t/-/43473, and at 3.5 amps output starts turning blue.
