This is the info from zeroair review:
Size and Comps
Size: 71.2mm (2.8″) length x 28mm (1.1″) head dia. x 25.8mm (1.01″) body dia.
I measure it as 72.24mm (long, 18350) x 28.05mm (head) x 25.79mm (body), and 100.31mm for the 18650 setup.
Weight: 82.8g (2.92oz) w/o battery, 109g (3.84oz) w/ battery
I weight it as the following: 42g (head), 38g (18350 body), 52g (18650 body).
phantom23
(phantom23)
January 24, 2021, 1:55pm
14
Rarely because it’s discontinued. I have the NW version, no need to swap the emitter.
lfb
(lfb)
January 24, 2021, 2:00pm
15
For the Emisar d4v2 I would choose the e21a that comes with 6 Amp regulated driver. I would also consider the Skilhunt m200. A little longer than 4” but still very compact and can put a good amount off sustained lumens.
ArtieT59
(ArtieT59)
January 24, 2021, 2:10pm
16
That’s a nice looking light.
Now I want one.
lfb
(lfb)
January 24, 2021, 2:55pm
18
5A. My bad. But my point is it produces over 400lm sustained without pwm.
phantom23
(phantom23)
January 24, 2021, 4:32pm
19
It doesn’t matter if it’s 5A or 6A - there’s no regulation on high mode, output falls off the cliff right after startup and it stabilizes on a measly ~450lm. I know it’s small but those are pretty weak numbers.
lfb
(lfb)
January 24, 2021, 5:00pm
20
Exactly, 5 or 6A doesn’t make any difference. I don’t know many flashlights, so I thought that sustained 450lm for a light of that size and hi cri was good. Looks like a FET+7135 is less efficient.
phantom23
(phantom23)
January 24, 2021, 5:20pm
21
Stock NW is about 4500K, no high CRI or anything (CRI is pretty low actually).
Nope, bone-stock.
Might be the “MH20W” but the ‘W’ isn’t etched anywhere on it. Wonderfully just-warm-of-neutral, guessing 4500K or so.
Got a coupla other MH20s as spares, but don’t recall if they’re NW or CW.
Yeh, I learned my lesson. Get something, like it a lot, want spares so you don’t have to be without one… GET spares before they get discontinued.
Kewl, so I guessed right. :laughing:
Lightbringer:
Wanna reinforce the stock?
Different stores with different prices :nerd_face:
https://www.aliexpress.com/item/4000437761970.html
https://www.aliexpress.com/item/32850138365.html
https://www.aliexpress.com/item/4000752191403.html
Blazer1
(Blazer1)
January 24, 2021, 8:04pm
25
Thanks Blazer, I have an SC31 Pro, great light, but I'm looking for options 4 inches or less.
I have a Folomov 18650s and a DQG Tiny 18650 inbound, excited to try them out.
Au contraire! My E14III with the 18650 tube is under 4 inches
Also, my Lumintop HL3A has to be one of the shortest 18650 lights ever made!
Yes someone pointed out my error above, I didn't see an 18650 extension tube mentioned when I looked at the light... thanks for the suggestion!
Penny wise but Lumen foolish:
Yes someone pointed out my error above, I didn’t see an 18650 extension tube mentioned when I looked at the light… thanks for the suggestion!
Yes I did, and then I posted this :
Ah, I see it now. As for your question, the E14 is about 3.95 inches according to my measurement.
Edit: and now I see that was already answered as well. Jeez, I need a coffee.
