Stock NW is about 4500K, no high CRI or anything (CRI is pretty low actually).
Nope, bone-stock.
Might be the “MH20W” but the ‘W’ isn’t etched anywhere on it. Wonderfully just-warm-of-neutral, guessing 4500K or so.
Got a coupla other MH20s as spares, but don’t recall if they’re NW or CW.
Rarely because it’s discontinued.
Yeh, I learned my lesson. Get something, like it a lot, want spares so you don’t have to be without one… GET spares before they get discontinued.
Kewl, so I guessed right. :laughing:
phantom23:Rarely because it’s discontinued.
Wanna reinforce the stock?
Different stores with different prices :nerd_face:
https://www.aliexpress.com/item/4000437761970.html
https://www.aliexpress.com/item/32850138365.html
https://www.aliexpress.com/item/4000752191403.html
My EDC, nice light, neutral tint, plenty of lumens, Anduril, quality battery and USB charging if that matters.
Thanks Blazer, I have an SC31 Pro, great light, but I'm looking for options 4 inches or less.
I have a Folomov 18650s and a DQG Tiny 18650 inbound, excited to try them out.
A for effort SerenityNow, but I’m looking for 18650 powered lights.
Au contraire! My E14III with the 18650 tube is under 4 inches
Also, my Lumintop HL3A has to be one of the shortest 18650 lights ever made!
Penny wise but Lumen foolish:A for effort SerenityNow, but I'm looking for 18650 powered lights.
Au contraire! My E14III with the 18650 tube is under 4 inches Also, my Lumintop HL3A has to be one of the shortest 18650 lights ever made!
Yes someone pointed out my error above, I didn't see an 18650 extension tube mentioned when I looked at the light... thanks for the suggestion!
Yes someone pointed out my error above, I didn’t see an 18650 extension tube mentioned when I looked at the light… thanks for the suggestion!
Yes I did, and then I posted this:
This is the info from zeroair review:
Manker E14 III 18350 Quad Emitter Flood Flashlight - ZeroAir ReviewsSize and Comps
Size: 71.2mm (2.8″) length x 28mm (1.1″) head dia. x 25.8mm (1.01″) body dia.
I measure it as 72.24mm (long, 18350) x 28.05mm (head) x 25.79mm (body), and 100.31mm for the 18650 setup.
Weight: 82.8g (2.92oz) w/o battery, 109g (3.84oz) w/ battery
I weight it as the following: 42g (head), 38g (18350 body), 52g (18650 body).
Thanks MascaratumB
SerenityNow: Penny wise but Lumen foolish:A for effort SerenityNow, but I’m looking for 18650 powered lights.
Ah, I see it now. As for your question, the E14 is about 3.95 inches according to my measurement.
Edit: and now I see that was already answered as well. Jeez, I need a coffee.
Not at those prices…
The one I’m using is the first, and that was about 70. The others were when I saw them discounted to 50 or less.
The MH20GT I’ve never ever seen discounted, so I only got 2, both “secondhand” from nice people here.
Funny thing is, I was intending to gift at least one of the regular ’20s, but changed my mind. :laughing:
Thanks MascaratumB
MascaratumB:Wanna reinforce the stock?
Different stores with different prices :nerd_face:Not at those prices…
Yeah, quite “not cheap” The first one is the cheapest and it is at almost 60! :money_mouth_face:
There are some other options with battery, charger and more stuff, so altough discontinued, they are still around
Although I do recognize how good they can be, they’re larger than what I like for EDC.
I normally like smaller lights, as OP is asking for. Current EDC is the Warrior Mini. Not the smallest , but has what I like in terms of UI.
Funny thing is, dimension for dimension, the MH20 is, within a mm or two, the exact same size as the i332, which takes a 16340! Not even an 18350, but actually a 16340.
So a ~4” light with charging, dual-stage switch, hella nice and simple UI, and full 18650, I’ve yet to have any other light dethrone it as my EDC.
Thought of another: lumzoo GH10
Amutorch AT40 should be just under at 100mm
Amutorch AX2
Thanks Scallywag, that AT40 looks nice, does the AX2 have an 18650 tube?
Nice suggestions Scallywag, really like that DQG Tiny !
not recommended
unless they change the switch design
phantom23:Stock NW is about 4500K, no high CRI or anything (CRI is pretty low actually).
the downside to spares is, by the time you need a new light, something better will be out
for me, the Anduril UI is a good reason for this…
i feel like the reason i like a given light is usually mostly the UI, and i think anduril will be around for a while, unlike other one-off UIs that came before
only on new and improving platforms
wle
Penny wise but Lumen foolish:Nice suggestions Scallywag, really like that DQG Tiny !
not recommended unless they change the switch design
Could you elaborate? Whats wrong with the switch design?
