✌ ASTROLUX EA01 SST40 (2300lm)/ XHP50.2 (3500lm) TIR 26650/ 26350 Flashlight Group Buy - ALIVE!
571 posts / 0 new
Artiet59
Last seen: 50 min 35 sec ago
Zoulas – here is the factory inserted Brass (the ring that has the two screws in it)
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
WindyCity
WindyCity's picture
Good to see the problem is solved, had it on my shortlist (that is getting longer and longer)
Chicken Drumstick
Yeah the revised MINI has a brass insert, you can see it easily when you remove the battery tube. Mine was the wrong way round (needed rotating 180 degrees). I also applied some thermal compound to the touch points under the heatsink.
zoulas
zoulas's picture
Last seen: 3 hours 43 min ago
Has this problem been addressed from astrolux? If I buy one now, will it be plastic still?
Chicken Drumstick
As said, I bought one a few months back and it came with a brass heatsink. I’d say problem solved myself. Smile
light_man89
I am interested in a coupon for the XHP50.2 version.
Thanks.
aggalitsas
Last seen: 1 week 3 days ago
Is it an established fact that 21700s batteries are a no-go for this light?
Artiet59
I use the 40t in both of mine no problems so far. I think that warning is just for the mateminco mt04 for some reason.
brenden23
Last seen: 5 months 18 hours ago
Please send code for EA01
aggalitsas
Thanx, I may end up buying this light and all 26650s I can buy are expensive and inferior to 21700s like 40T
Rat
Last seen: 18 hours 55 min ago
XHP50.2 Blue code, please
d_t_a
Last seen: 1 day 11 hours ago
21700 batteries will fit the EA01 with adapter, although may get slightly compressed if it’s a bit longer (unprotected) 21700.
With EA01 (with XHP50.2), I’d say 21700 batteries will be good.
Unfortunately my EA01 (with SST40), turns bluish even when using not-high-drain 26650 batteries… since it shipped with this bluish-on-high-brightness problem… BG is “still processing” my complaint for this issue… Sad They mention will send a new light bulb to me (I wonder what it meant — I doubt they mean they’ll ship a complete replacement flashlight since they just said “light bult”…)
-Rick-
Last seen: 4 months 4 weeks ago
Interested!
aggalitsas
Hope everything turns out fine with BG
djozz
djozz's picture
Last seen: 10 hours 55 sec ago
I received a nice Acebeam E10 today (it was my prize for the OL competition Party ), which is the same form factor as the Astrolux EA01, so here they are next to each other for comparison.
The Acebeam is lighter built, w/o battery it is 98 gram, vs 133 gram for the Astrolux. The TIR’s are the same diameter and work the same, but they are not the same TIR. No idea if one is better than the other, these two flashlight have a vastly different emitter (SST40 and White Flat) so the beams and throw can not be compared. The Acebeam 26350 battery with charging port is well too long for the Astrolux.
Nagonka
Last seen: 3 months 1 day ago
Already alive? I’m interested in the SST40 Version.
pennzy
pennzy's picture
Last seen: 38 min 3 sec ago
If still available, I would like a code for a black XHP 50.2 please.
Dzeric
Last seen: 2 hours 15 min ago
Will this eventually be available with colored orsam emitters?
greymage
Last seen: 4 days 15 hours ago
May I have a code for the XHP50.2 version please?
Thanks.
freeme
freeme's picture
Last seen: 1 hour 18 min ago
All replied.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
Nagonka
Sorry, think you forgot me Sad
XHP50 Version
TheAuditor
Last seen: 2 min 22 sec ago
Has anyone else had the turning blue issue with the SST40 version?
Bonum commune communitatis.
Yarp.
Artiet59
I have not. I Have sst40 5000k
djozz
djozz's picture
Could be a chip of alu under the ledboard preventing good thermal contact with the body. Or one of the holes in the ledboard shelve that has a protruding edge.
Depending on your mood or skills you could
1)contact Banggood about it, or
2)open the head, unsolder the ledboard and have a look at what is wrong. Then assemble the proper way.
light_man89
Ordered Grey XHP50.2 5700K
Thanks.
pennzy
pennzy's picture
Thanks freeme, order placed. Hope it ships before Feb. 23rd.
pennzy
pennzy's picture
What battery gives the longest run time and can handle the XHP50.2 amp draw. I don’t need every last lumen.
-Rick-
Rick wrote:
Interested!
And ordered Wink
phantom23
phantom23's picture
Last seen: 3 months 4 weeks ago
Just get the highest capacity ones and avoid turbo. High (the highest ramping mode) is still plenty bright.
pennzy
pennzy's picture
That used to be the Shockli 5500 but I think it has been discontinued? How many amps is turbo with the xhp50.2 in the EA01?
