When given the choice, I think its always best practice to select a –0.0020 DUV in the neutral whites (3750-5250K). In my opinion, when you go above or below this, returning to the BBL is fine.
SKV, I wasn’t so lucky with the 4000k fc40 sample that I received late 2020. I don’t have a way to measure, but I’d say its well over +0.0100. With two layers of eighth minus green AND Joshks paint, its still slightly green. Honestly the subjective color rendering before tint correction was easily worse than 80cri XPLHDs and even my 4000k MTG2. Saturation was terrible. Its okay now, but there’s angular tint shift due to the filters and output has dropped too much. Waiting on one from Simon now. Hope these truly are BBL.
if you think about raising driver current specifically for this host + led combination, I think, 3A would be the best setting (keeping in mind, that this host is smaller than L6 and L21A).
Anything change with the XHP35 to run at higher amps? From this old test here, it peaks at ~2.5 amps: https://budgetlightforum.com/t/-/43473, and at 3.5 amps output starts turning blue.
Clearance will help for a bigger coil, and depends. For example on the original BLF GT buck driver DEL designed, he had designed in more amp capability, think ~5 amps or so, if I recall.Of course there was plenty of room on that driver in that light.
Can someone to tell me what is the driver diameter of new S21B. It is 22mm? From Simon store I saw that XHP50.2 version used the new 3A boost driver which is 22mm. Also now we also have very good buck driver for 3V in 22mm so we have nice S21B host for new switching drivers from Convoy, if it used 22mm drivers.
