Baivic Titanium Alloy LED Flashlight V4+
Hi, just update the output value, for the driver, I will check and update.
Thanks
This looks interesting and at a reasonable price too.
The sandblasted one is really nice looking. :+1:
this one is also nice: https://geardamascus.com/products/mokume-3-nicha-219c-led-monster-edc-flashlight
but there is no knurling... good looking though
Yep, lovely - material speaks for itself - personally I’d rather have it plain (ish).
Thank you for adding the lumen numbers.. and output overview.
But how does it work?
Does it start in beacon? or in Turbo? etc
Yeah, I was remembering this design from before!
Last year Martin made this GB: Custom Titanium flashlight groupbuy
No pics there (or maybe I can’t see them), but go to the search and type custom titanium and the images will appear there and are related to that thread !
Pictures are showing! :person_facepalming:
Nice design :+1:
I see, that definitely looks the same
Yes, bangood said they need 40 pcs but didn’t pick up so I post it here.
Did you ask how the UI works?
V4+ flashlight UI:
ON/OFF: Click the tail switch to turn on or turn off the flashlight.
Output selection: Tap on the tail switch to go through all output levels and click to select.
Selections switching: Tap on the tail switch 10 times continually and click, the light will be off for few seconds, then it will blink 5 times for 2 rounds, during which you can switch to other output selections via a click on the tail switch.
and the output selections you will switch into depends on which blink you click the tail switch.
1st blink: Medium1-High-Turbo
2nd blink: Eco-Low-Medium2
3rd blink: High-Turbo-Strobe
4th blink: SOS-Breath-Beacon
5th blink: To change between output level with and without memory.
Default setting: without memory.
I'm wondering what happened to the store!?
A few days ago it was still working.. now it's gone
This is working for me: https://www.geardamascus.com/ (with the www on the address)!
Check if it works for you too :wink:
Just checked, the site only works with www prefix :+1:
Thanks.. that works
I received the flashlight!
I was thinking about the user interface, and I would like to point out a few things:
Current setup:
My ideas:
I like the 2nd mode configuration for kids, but 1 3 and 4 are not very well thought out.
1: people miss a low
3: not very interesting for most people, a single mode would be better, or just a simple Low High
4: most people probably don't use flashlights for just blinkies, a single mode would be better, (for 1 normal mode or 1 blinky mode)
currently, High is too close to Turbo in my opinion in terms of output. I will be reviewing it so I will get the exact numbers.
****My suggestions: **
1st blink: Mode group 1: Eco, Low, Medium, Turbo
2nd blink: Mode group 2: Eco, Low, Medium (great for kids)
3rd blink: Mode group 3: Turbo, Medium, Low, Eco (reversed from group 1)
4th blink: ??? single mode??? (could be any normal mode, or even a blinky mode)
5th blink: mode memory toggle on/off
That's probably covering most of the stuff people are interested in.
Do you know if this is grade 2 or 5 Ti?
Reviewed the Baivic V4+ here: https://1lumen.com/review/baivic-v4-plus-titanium/
I can also post a short version here, if you'd like.
No, I don't know. How can we see the difference?
Only the guy sourcing the metal would know :-)
@LumenMax: got it.. thank you
Any updates on the Baivic V4+ modes, @Flashlightfun
Any updated on any other new models?
