The TI PWM chip regulates voltage on a cycle-by-cycle basis at 500 kHz, so only 8 bits of current sense measurement can develop a 1:10M range. For example 240 current levels for each of 41666 voltage levels.
Analog resolution, not digital.
For example: The Emisar D4 has a dynamic range of 16,000 to 1… 14 bits worth. But it uses only 8-bit PWM, which is 256 to 1. How is this possible? It has two power channels — one which goes from 0.25 to 130 lm in ~0.5 lm steps, and one which goes up to ~4000 lm in ~15 lm steps. Two 8-bit channels combine and produce an effective resolution of 14-bits.
But what if the low channel was smaller, and it used 10-bit PWM instead of 8? If the low channel was only 16 lm, that would increase resolution to 0.015 lm steps. 4000 lm / (16 lm / 1024) = 256,000, or approximately 18 bits of analog resolution (on hardware which is only 10 bits digitally).
If it helps, some related ideas are shown visually here:
Ignore the bottom part. It is only showing the importance of good current control to make the ramp more smooth.
On every flashlight in the repository, the bottom of the ramp has been artificially shortened because the resolution isn’t high enough in the hardware. It would otherwise end up with a ramp which looks like “1,1,1,1,1,1,2,2,2,2,2,2,3,3,3,4,4,4,5,5,6,6,7,7,8,9,10”.
But with your solution, it seems like it’d be able to hit the in-between levels at the bottom. The intended values are “1.00, 1.07, 1.15, 1.25, 1.35, 1.47, 1.59, 1.74, 1.90, 2.07, 2.27, 2.48, 2.72, 2.99, 3.27, 3.59, 3.94, 4.32, 4.74, 5.19, 5.69, 6.23, 6.82, 7.46, 8.16, 8.91, 9.73, 10.62”.
I didn’t understood that. What do yo mean? 500khz is operating frequency of the boost driver itself. It doesn’t have to do with control loop. In our case we have CC driver not CV in most of time. Also Anduril firmware must support that functionallity with second channel of dirver. Now we have simmilar idea like old FET 3 channel drivers.
ToyKeeper thanks for the detailed explanation :+1:
This is tremendous - I’d love to purchase a flashlight with this kind of driver design.
Ah so this is similar then, this is encouraging for my novice EE mind, thanks for the answer.
The thrunite T2 has a 0.3 lumen so that’s pretty low, especially compared to the max output. Zebralight have been producing flashlights with very low moonlight levels for years, it would be interesting to know how they do it as well. Manker E02 and E03, very small lights with boost converter and ultra low moonlight.
Attiny 1 series also have a calibrated temp sensor, if you added an external one then that’s that less on the board.
ToyKeeper what do you think about that: Dual PWM Circuits | Open Music Labs
Also here is similar idea released with MSP430 mcu A Faster PWM-Based DAC
It is similar to your approach to combine two output current control channels. This is very simple and clever solution to achieve higher PWM DAC resolution from dual PWM channels. Also that will be very good for trusted old Attiny85. With linear driver this is very good solution I think. But I think there is needed little modifcation of code to be released LSB and MSB from dual channels. With that approach we now can have very good ramping.
Thanks ToyKeeper, your diagram is instructive and explains it well.
I'm not sure if I explained myself well; Lume X1 helps with the lower part of the ramp table in that the lower values are not rounded off to their nearest integers; i.e. in the Lume X1 ramp table, all values of each of the 150 levels are different. However, because there are only 150 levels, each jump from level n to level n+1, is still noticeable, especially at the lower levels (at least with a x^3 curve). We can increase the smoothness of the curve by adding more intermediate values (e.g. more levels), but I have not done it yet because adding more levels increases the ramp up and down time (and AFAIK, it's not a straightforward change to change each tick duration).
When I have more time, I'd like to try out some different ramp curves and ramp lengths though. Browsing available literature, it seems like there is a guideline that Perceived brightness = Sqrt ( radiant flux ), so I'll be trying out those kinds of curves, which flattens out the lower end, making each step less at the lower end (where my eyes seem more sensitive), and larger at the higher end.
icpart and thefreeman, interesting discussion, I'd like to try it out to see how it could improve performance. :)
Browsing available literature, it seems like there is a guideline that Perceived brightness = Sqrt ( radiant flux ), so I’ll be trying out those kinds of curves, which flattens out the lower end, making each step less at the lower end (where my eyes seem more sensitive), and larger at the higher end.
Yup - it takes about 4,000 lumens to seem "twice as bright" as 1,000 lumens. This square law is why I abandoned my hot-rod mod quest after I built a light that should be doing 10k+ and couldn't really tell the difference (especially with radically different lux values) to my ~7,000-8,000 lumen light. I figure I'd need to crest 30,000 to actually start caring about the difference, and I'm not ready to build something with the proper combination of size, active cooling, etc...
Of course, we have the same issue with throwers, where throw is proportional to the square root of candela. So to get twice the throw of a 1,000,000cd light you need 4,000,000...
Very impressive, the looks with the Olga…
Amazing work - another level. I feel I’m peering into the future of flashlights. Hopefully the near future!
My ideal everyday flashlight would be something like the Zebralight SC700d - it’s extremely compact (smaller than many 18650 lights even though it has a 21700 battery), extremely well built, has a high efficiency driver, and has an e-switch. As far as I know, there is no competition anywhere close to this flashlight, and certainly none running the wealth of features provided by the open-source Anduril.
Although it wouldn’t have fit this exquisite Olga optic, I would like to call some attention to the uncommon Lumintop FW21 (non-Pro), a light which I thought was unfairly dismissed upon release. It was an FW3A scaled up very slightly to fit a 21700 cell - even smaller than the SC700d in all dimensions. The body had rather superflous trit slots, and it advertised the same 2800lm max output as its smaller sibling. Furthermore, early production examples (mine is one of them) have an extra-long body tube that only works properly with protected 21700s. Still - it fit a 21700, while being the same size as a Noctigon KR4. I wish more work had gone into its development.
Lumintop FW21 […] I wish more work had gone into its development.
That’s exactly the thing: Lumintop just did it, and as with most of the rest of the stuff they just did themselves, it came out pretty poorly. Even the original FW3A never got the manufacturing quality we wanted from Lumintop, and they’ve continued to “cost-optimize” it and all its variants ever since.
I can only recommend the FW3A with caveats these days, and the rest of the lineup I can’t recommend at all in good conscience.
… It is similar to your approach to combine two output current control channels.
Yes, it is almost exactly what BLF flashlights have been doing since ~2014 or so. But most BLF lights only use the extra resolution in low modes, because that’s the only place the resolution is perceptible, and because it eliminates the hassle of dealing with variable ratios between power channels. Like, the size of the FET channel’s steps changes throughout the life of each battery charge, but the 350mA channel’s steps stay pretty constant. So adding them as shown in that link results in step size alignment problems — like shown in my diagram where the 20 mA channel and 5A channel produce different shapes depending on voltage.
The next thing I hope to try is a different method entirely… combining PWM with DSM (delta sigma modulation). The effect is similar to increasing the bit depth, but it doesn’t have the downside of slowing down the pulse rate. Basically, instead of doing a value of 5 / 9ths as “111110000”, it encodes the value as “101010101”.
So this would effectively enable 15-bit or perhaps 16-bit digital resolution on an attiny chip, while still pulsing at ~16 kHz. The main problem is that it’s more difficult to implement, since it requires doing some math and adjusting the pulse width on each pulse cycle. So it needs extremely tight timing on an interrupt which fires off rapidly.
The other difficulty of increasing the digital resolution this way is that it would require some changes to the abstractions on which Anduril is built. Some of the code, like the “set level gradually” mechanism, works by adjusting the output in hardware-resolution steps of 1. It works for the current set of lights, but it would be way too slow when the resolution is increased. Some of the underlying code would need to be rewritten to change from abstract ramp steps to actual hardware power levels… and that’s tricky.
Thanks for the comments everyone!
ToyKeeper, a nice idea, but like you mentioned, could be a little tricky to implement in code to achieve the desired performance. I'm not sure if a PSOC (they come in a 2.3 x 3.2mm BGA for the 4200) has sufficient programmable logic blocks and peripherals to implement it on chip, but I suppose it's not a realistic scenario since we're working with ATtinys for now. But it's an interesting approach for sure.
Scallywag and 000-Bluefire, I think the FW21 was a decent flashlight, but like you said, it felt a little like a copy and paste. I had one for a while and had palnned to use it for a prototype, but I sold it in the end because it was a little too similar to the FW3A and didn't really offer anything additional other than it holds a 21700 cell.
Speaking of the FW series, I have a FW1A on hand... wondering if you all think it would be a good idea to put a Lume X1 in it, with say a XHP70 LED, or even an older but fun MTG2!.. (anyone know any drop-in TIR replacements for the FW1A aluminium reflector?).
I recently got a Amutorch E3 (which looks like a Zebralight copycat), but I like the idea of the side switch, unibody machining, and very compact size for a 21700.. could be a good candidate for the Lume X1. I wish more manufacturers went with this kind of unibody design, but preferably not copying Zebralight since many manufacturers have shown that they are capable of good, original designs.
Gchart, I started working on a 1616 or similar proto, thanks for the work you've put in! From what I see it looks like Anduril1 has been ported over; has Anduril2 been done as well? I could have missed it..
Gchart, I started working on a 1616 or similar proto, thanks for the work you’ve put in! From what I see it looks like Anduril1 has been ported over; has Anduril2 been done as well? I could have missed it.
This bzr repo was branched from TK’s anduril2 branch. It should have all of the Anduril2 goodies running fine. I’ve got Anduril2 loaded on several t1616 flashlights. I haven’t tested it with RGB Aux yet, but the code is there. To my knowledge, that should be about the only untested thing. This is same repo that I had linked to previously, but I changed the name/url today… I’m relatively new to bzr and I didn’t realize that I didn’t have it linked back to the main Flashlight Firmware Repository properly.
Amutorch 3 looks good only from outside but its not really good option for powerful boost driver modding. PCB have fixed button and 2 holes and bad contact with host
“This bzr repo”:anduril2 : Code : Flashlight Firmware Repository was branched from TK’s anduril2 branch. It should have all of the Anduril2 goodies running fine. I’ve got Anduril2 loaded on several t1616 flashlights. I haven’t tested it with RGB Aux yet, but the code is there. To my knowledge, that should be about the only untested thing. This is same repo that I had linked to previously, but I changed the name/url today… I’m relatively new to bzr and I didn’t realize that I didn’t have it linked back to the main Flashlight Firmware Repository properly.
Thanks! I'm going to take a look at it.
“Amutorch 3”:AMUTORCH E3S ---Guess its length, Win a Free E3S! (revealed) - #242 by Tom_E looks good only from outside but its not really good option for powerful boost driver modding. PCB have fixed button and 2 holes and bad contact with host
The fixed button looks perfect IMO; for the manufacturer it allows lower part count cost and simple assembly. Though from what I saw of some teardowns, it uses a RA switch instead of a board in-line design which would be more robust. As for the contact with the host, that is true, but I think it could be mitigated with some brass screws or hard gold plated ones (ideally they would mill out the anodizing for the shelf which would also help). I won't know until I see it in the metal though..
Loneoceans, I have a bunch of exact diameter TIRs I can send you. They might be short by a mm or two, but I’ve seen you make easy work of that before. I haven’t been happy with their performance, but they’re free to you. PM me and I can ship them over.
…specific PCB shape it will fit only this flashlight ;))
If this driver technology would be implemented in close release serial flashlights? Name, o sister!
