New Member needs help with Battery Test Readings
26 posts / 0 new
HowieG
I am trying to sort out my drawerful of rechargeable Ni-MH batteries. I decided to use for the first time the Test function on my La Crosse BC-1000 charger. The results of my first foray are here:
These batteries are rated 2100 mAh. After the test finished, the charger indicated as follows for the four batteries:
1. 1713 mAh
2. 2.00 Ah
3. 2.02 Ah
4. 2.00 Ah
Why is the first reading in mAh but the other three in Ah? Are are four batteries shot? Or is #1 the only bad one?
Thanks!
Edited by: HowieG on 01/30/2021 - 17:47
HowieG
Hmm, don’t know why my picture didn’t show up. I pasted this URL in the “Insert Image” dialog; https://www.dropbox.com/s/9y2stcjot9iu0sv/IMG_0846.jpg?dl=0
JaredM
JaredM's picture
Last seen: 36 min 23 sec ago
The charger may have formatting settings that change at 2000 mAh, I wouldn’t sweat that. Next, I’d say to run them all again in the same slots now that they are all discharged. Then a third time in different slots. Average the values then compare.
d_t_a
Last seen: 5 hours 28 min ago
The display screen appears to be only able to display a “1” on the first digit (cannot display a “2”), thus when it goes higher than 1999, it will become “blank-2.xx” display —- at least that’s my guess.
As the above mentions, try rotating the batteries and re-test in another slot (maybe mark them first) — it could be each slot just has a slightly different reading, or the first battery is slightly more degraded than the other 3 batteries, but 1700mAh seems to still be OK, just slightly degraded… (which may mean its internal resistance may have gone a bit higher too; but may need a different charger / device to check resistance, which is also another important characteristic to test for batteries, in addition to capacity test readout.).
raccoon city
raccoon city's picture
Last seen: 1 hour 2 min ago
Make yourself at home, HowieG!
There is a link in my signature on how to post pics on BLF.
Some people seem to have trouble posting pics from Dropbox.
109_milla
raccoon city
I clicked on your link, then right clicked on your image and chose "open in new tab", then took that image's URL and that's what I posted.
HowieG
Thanks everybody for your very helpful posts! Thanks, too, to racoon city for getting my picture up. I will check out your advice on posting pictures.
jon_slider
jon_slider's picture
Last seen: 8 hours 9 min ago
raccoon city wrote:
I clicked on your link, then right clicked on your image and chose “open in new tab”, then took that image’s URL and that’s what I posted.
I do not see an image in your post, just an empty box
raccoon city
Maybe Dropbox doesn't play nice with BLF?
jon_slider
the link in post 2 works to show the image
copy image location works to post that image here (using insert image icon):
no
no
the rated capacity is 2100mAh (=2.1 Ah)
the tested capacity of 2.whatever is very close
the 1713mAh = 1.713Ah, and is 19% below new capacity, it might not last as long, but it is not “shot”
raccoon city
That copies the exact same URL that I used to post the image, by the way.
I think you copied the image, not the image address.
jon_slider
they are not the same, and your post does not include the insert image tags.. (The ! at begin and end of the image address)
raccoon city
jon_slider wrote:
but your post does not include the insert image tags.. (The ! at begin and end of the image address)
That's because I am using the Advanced Post Editor, and the "! trick" doesn't work with the Advanced Post Editor.
Also, the "! trick" is not required for the Simple Post Editor.
jon_slider
Im not using a trick.. I used the Insert Image icon, which has the effect of framing the link that I got with copy image location, between ! !
anyway
I respect your efforts to help the OP with image posting.. I hope he figures it out.. it Can be done Smile
raccoon city
I am using Opera, which is similar to Chrome.
Copying image address gives you the exact same URL as my method that I described earlier (in Opera.)
It may be different for different browsers.
raccoon city
Okay, I didn't know that.
I thought that exclamation marks only show up if you type them.
Wow, this thread really got derailed.  :-)
jon_slider
I looked very closely at the image address you posted:
https://ucb8f4fc78bfe52be0f2669268f3.previews.dropboxusercontent.com/p/t... alt=”“ width=“640” height=“480”
it is in no way identical to the image address I posted..
https://uc632129679689837d14ce4c3916.previews.dropboxusercontent.com/p/t...
I dont know why
It does appear that your way of posting images does not use the ! marks, it uses a different code that says
<img src=
if it works for you, there is nothing wrong with doing it that way..
I hope the OP figured out whatever he needed to know Smile
raccoon city
Like I said before, I'm using Advanced Post Editor and you're using Simple Post Editor.
Which internet browser are you using?
jon_slider
raccoon city wrote:
Like I said before, I’m using Advanced Post Editor and you’re using Simple Post Editor.
I agree your post editor uses different codes
also agree different browsers pull different image addresses
here is the result using Safari, for my earlier post I used Firefox (both work):
raccoon city
jon_slider wrote:
I agree your post editor uses different codes also agree different browsers pull different image addresses here is the result using Safari, for my earlier post I used Firefox (both work)
I don't have Safari, but I confirm that Firefox gives a different URL than Opera.
So I learned a couple of different things about posting images on BLF today.  :THUMBS-UP:
raccoon city
@HowieG:
Since Dropbox seems to not get along with BLF so well, you might want to try a different image hosting site to post images on the forum.
jon_slider
me too Smile
I did not realize there were different image address codes for different browsers, plus different image linking codes.. thanks for sharing info.
dropbox does work for me, but it seems like the links are really long
and maybe Dropbox image links are browser specific, which could explain why I cant see your pic..
can you see mine?
I have been using imgur to host images, it has been working well, and I recommend it as an alternative image host option to the OP, if needed
raccoon city
jon_slider wrote:
can you see mine?
Yep, I can see yours, and I frequently recommend imgur.com to most English-speaking people.
I use abload.de, but it's in German, so it's not that convenient until you memorize how the site works.
jon_slider
raccoon city wrote:
I can see yours
ok, well one link came from dropbox using safari, and the other came from dropbox using firefox
(I did not use imgur, I used the link the OP gives in post 2, and then when his image loaded, I used copy image location, and finally I used the Insert Image icon, here on BLF…)
so I still dont know why I cant see your pic in post #6.
apparently its not because of the browser you use being different than mine.. but not sure
can You see Your pic in post #6? Smile
(what a mess of a thread… lol)
raccoon city
I can see my pic.  ;)
I think the specific issue is me getting the Dropbox URL with Opera, and then you not being able to see that pic in Safari or Firefox.
It seems that Dropbox gives a different URL for every internet browser, and some of those URLs don't work with every other browser.
jon_slider
raccoon city wrote:
It seems that Dropbox gives a different URL for every internet browser, and some of those URLs don’t work with every other browser.
thanks, that sounds true
I agree w your recommendation to use a different image host than dropbox
respect for your time and effort to help others learn to post images.. pics add a LOT to a post, its worth figuring out, imo
