1A max charge current? Looks like a bad joke for 5000mAh@21700 batteries, 5+ hours of charging! USB-C with no support for QC or PD - is it really 2021 now?
I tried my vc8 with a generic usb c cable, and their ac adapter, it works but it would not charge at 1,2,3A currents, it was under 400ma, once i plugged their wire got 3A.
That is so dumb, they clearly can make a properly functional usb PD charger because the PB2s exists. If they could scale up the PB2s to 4 bay and add ni-mh support (even if the powerbank function was disabled) then I’d be buying one.
Make a 30W AC adaptor (and support USB PD), and make it to support 1.5A charging on all bays simultaneously (probably this would need a bit more advanced cooling mechanism to be implemented), then it will be a much more up to date design.
Hi, the VC4L can also charge with C to C cable, pls check the pic below.
Both USB-A to USB-C and USB-C to USB-C cables are fine. May I know what kind of cable you use?
I bought one of these because I like the VC4. I’m charging some protected 21700 cells now. I like the new usbc plug too I wont have to worry about bringing an extra cable with me when I travel.
Ok so I’ve tried various usb c to c cables I’ve got.
Didn’t work with any 100w rated cables I own, Anker, choetech and Spigen. I can link the exact cables if needed when I’m on the computer.
It works with the 60w rated cables I have, various ones from ugreen, Anker, choetech, spigen. The only 60w cable it didn’t work with was a usb IF certified cable from choetech
So it does work with some cables but can’t seem to negotiate with a 100w rated cable so at the very least it would seem like the port hasn’t been implemented completely as it should still charge.
Compatibility with protected 21700 looks nice, but with a max. charging current of only 1 A, it would take something like 6 hours to charge a fully depleted 5 Ah cell.
Nowadays, I consider 1 A unnecessarily slow even for most 18650 cells, and 2 A is the lowest charging current for 21700 in order to keep times on the charger reasonable.
Using the capabilities of QC and PD over USB-C, it would have been possible to design it with at least two slots capable of charging at 2A.
My guess is that having QC may make the charger more expensive?
The Xtar SC2 does use QuickCharge to allow 2 slots to charge at 2 Amps per slot.
while the Xtar ST2 requires USB-PD which allows 2 slots to charge at up to 4 Amps per slot.
I suppose the FC2 is supposed to be a more all-around entry-level but still versatile enough to handle both NiMh & Li-Ion battery types and also different charge currents.
