Keeppower 18650 3500mAh P1835U (White-blue) 2020
Official specifications:
Minimum Capacity: 3350mAh
Nominal Capacity: 3500mAh
Nominal Voltage: 3.7V
Discharge End Voltage: 2.5V
Standard Charging Current: 1.0A
Max. Continuous Discharging Current: 5A
Built in micro-usb charge port
A 3500mAh protected 18650 with build-in USB-charger.
A pack contains two batteries and a dual usb charge cable.
The two cells tracks nicely and can handle more than 7A before getting too hot or protection will kick in.
It looks like the USB charger reduces current probably due to temperature at the start of charging.
Conclusion
A good protected battery with good capacity, the USB charging can be useful on the go or if you only have a few 18650 batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
