Interested for 2
interested
Interested.
Depending on test results and shipping fees.
Yes please.
interested.
Battery not removable?
Do the color bodies glow in the dark also? Same brightness as the glow in the dark one shown?
interested for 3
Slot 47, I’m IN! Pick me! Pick me!
Interested
Interested
Interested.
Q: Spec says LiPo battery. Is this correct? What is the expected life of the battery? My experience with small RC planes and the like. Small LiPos have a limited life then swell up and massively reduce performance until they are no good at all.
If the battery is not removable or is proprietary, no sale from me. This only serves to significantly reduce the value of your investment.
- Most probably.
- Let me find out if they have a figure for battery life cycle.
- And also if the are able to provide spare battery for DIY replacement.
Preorder will happen soon.
Operation (machine translated)
In the operation logic shutdown mode,
- Click to return to the stepless dimming memory position. Long press to enter the stepless dimming. Default minimum brightness. Long press until extremely bright.
- Double-click to enter the burst flash Turbo position.
- Triple click to enter the auxiliary function.
- The light position defaults to uv/white light,
- single Click to enter the red light,
- click to enter the blue light,
- click to enter the red light to flash,
- click to enter the blue light to flash,
- click to enter the red and blue alternately flashing
- Four times to enter the voltage detection position
- Five clicks to enter the locked position, and five more clicks to unlock
- Six clicks to enter the RGB breathing light switch mode
- Seven clicks to restore factory settings
10 clicks to lock and unlock kills the deal for me.
There is absolutely no reason to make a flashlight without a removable battery other than controlled obsolescence.
Interested in one or two.
Two orange please.
I disagree with this.
What makes this style of light possible is the use of a pouch cells.
Advanced users will be able to replace them.
And you definitely don’t want regular users to handle them.
OK, they could in principle design an enclosure for the cell.
But then the light would be larger and very few users would buy a proprietary spare like this anyway.
