Latest release Vapcell 21700 5600mah 12.5A battery
Thank you very much for your suggestion. We will communicate with software engineer and mould engineer about S4+
Are you sure there is a market for the charger with 8 slots for analyzing discharge and measuring capacity?
Is there a similar product in the current market?
Thanks
Dennis, maybe it's worth to start a separate (development) thread for a sophisticated 8-bay analyzing charger made by Vapcell. What do you think? This thread here should better remain your promotion and advertising thread. ;-)
It's no secret that another manufacturer is doing a joint-development with a well-respected BLF member to launch a 4-bay analyzing charger to the market.
See all the information publicly available here:
https://budgetlightforum.com/t/-/57498
If I may add, the outcome of the feature list could be quite valuable to Vapcell, too. Lots of great ideas and thoughts that would be reasonable features in a battery charger.
If you are really interested to fulfill our flashoholics dreams, I would suggest to have some frequent mutual open communication with BLF, so we can talk about what can and cannot be realized and what milestones might be reasonable in terms of designing, testing and launching the new product. For instance, thorough testing will be a crucial point and so it might be a good idea to send some samples to skilled electrician experts like Henrik Jensen (HKJ) or BlueSwordM.
So, coming back to your question if there is such a device on the market yet: No, there is not actually. There are some nice 8-slot chargers but they all lack those great features that enthusiasts, battery experts and flashoholics have only found in some few 4-slot chargers like SkyRC's MC3000, Vapcell's S4+ or OPUS chargers. And still, even those few chargers deserve some minor improvements to become great.
Here's a list (not complete) of popular 8-slot chargers:
Xtar VC8
https://eu.nkon.nl/xtar-vc8-batterijlader.html
Efest LUC V8
https://eu.nkon.nl/efest-luc-v8-batterijlader.html
Efest Lush Q8
https://eu.nkon.nl/efest-lush-q8-batterijlader.html
Enova Gyrfalcon All-88 (can charge 8x 26650 at once!)
https://eu.nkon.nl/gyrfalcon-all-88.html
Miboxer C8 (tested by HKJ)
https://lygte-info.dk/review/Review%20Charger%20Miboxer%20C8%20Smart%20charger%20UK.html
DLYfull M8 (tested by HKJ)
https://lygte-info.dk/review/Review%20Charger%20Dlyfull%20M8%20Battery%20Charger%20UK.html
ISDT N8 (tested by HKJ)
https://lygte-info.dk/review/Review%20Charger%20ISDT%20N8%20UK.html
Efan Air M8 (tested by HKJ)
https://lygte-info.dk/review/Review%20Charger%20Efan%20Air%20M8%20Intelligent%20Charger%20UK.html
Could the buzzer be turned off and on when the backlight is turned off and on?
E.g.
Press DISPLAY to change slots.
Hold DISPLAY for 5 seconds to turn the backlight off and disable the buzzer.
Hold DISPLAY for 5 seconds to turn the backlight on and enable the buzzer.
EDIT: Iā€™ve already removed the buzzer. :stuck_out_tongue:
Folks, bear with me in this question, that is sounding too absurd for myself, but, you know, I need to clarify myself.
The new Vapcell 18500 M12 1200mah 10A Li Ion, wasnā€™t tested yet, but I would like to know, theoretically:
having the same capacity as an Aspire 18350 (between 1100-1200mAh), both cells being rated to +10A, the Vapcell to 4.44Wh and the Aspire to 4.07Wh, will there be any substantial difference when pushing these cells to their max?
Using a flashlight with FET driver, triple emitters, and so onā€¦a pocket rocket! Will there be substantial differences?
The first batch Aspires are a few years old already. The later batches were worse.
But this doesnā€™t let me answer your question, I donā€™t know.
I have some of the 1100mAh batch, which seem to be better than the 1300mAh teste by HKJ.
I guess I will place the question directly to HKJ, eventually.
Thanks Agro. :+1:
I think the bigger difference would be in the long run assuming the composition is different. Maybe one maintains higher voltage in storage and/or has more charging lifecycles.
Believe it or not, my T50 (Samsung 50S) order has arrived after 66 days (about 40 days "vanished" between NL and DE). It almost felt like Christmas opening the cardboard box. :-D
I did some measurements right away:
Resting voltage: 3.45V
Impedance: 9.5mOhm @ 1kHz AC via SM8124A
I noticed this battery - probably like all Samsung cells - has a slightly recessed positive flat top terminal.
66 days, thatā€™s nothing compared to my S4+ charger that i ordered Dec 8-2020 and received 24-Feb 2021
Hi, I made some research but couldnā€™t figure out everything so if its possible I need some help,
Iā€™m looking for a few batteries and I will use them with;
Mateminco MT01 XHP50.2
Mateminco TK04 XHP50.2
Many 21700 batteries in my mind now such as,
Vapcell T50 5000mah 20A/35A (samsung 50S) (seems like everyone loved that battery)
Samsung 40T (solid legendary)
Vapcell G40 4000mah (30A/45A) (no body talks about it, I couldnā€™t find information but sounds like very promising)
Vapcell F40 4000mah (25A/40A) (no body talks about it, I couldnā€™t find information)
These 2 seems perfect for lantern usage?
Samsung 50G (green,version 2)
Samsung 48X (green,version 2) (similar like 50G but 48X perfect for a long run. Good life time better for environment)
Also what I couldnā€™t understand is samsung 40T has 30A max continuous discharge but Vapcell T50 with 20A has almost same continuous power like 40T how is that possible?
Is T50 unrated or wrong rated?
(And also any thoughts for Vapcell G40 30A continuous will it be even better than samsung 40T and vapcell T50 ?)
Thank you so much for your time!
i know its probably not - but is there anywhere we can order these right now? even if only to get back order notifications?
Just giving my thoughts, but Iā€™m no expert so just consider as referenceā€¦
Iā€™ve gotten a pair of Vapcell G40 4000mAh 21700 (white wrapper) ā€” this does not appear to be the same battery as the Samsung 40T, itā€™s heavier (~74 grams vs ~68 grams for Samsung 40T), and G40 has a slightly wider diameter (I measure 21.3-21.4mm for G40 vs the 21.0-21.1mm for 40T). Also, the top design is different (both are ā€œ3-lobesā€ but the lobe design is different enough).
With that said, I canā€™t reliably test if G40 performs similar or better/worse than 40T. Using YR1030 AC IR meter, I noted that the G40 has AC IR ~8.2mOhms while a 40T has ~8.8mOhms, so the G40 has a wee bit lower AC IRā€¦ this isnā€™t enough to prove anything though. Both are quite low IR though.
With regards to the discharge rating, I wouldnā€™t exactly trust the rating of the rewrapper, but instead check for 3rd-party technical reviews (eg. from HKJ or Mooch); unfortunately I also havenā€™t found info about the G40 (or F40) from either HKJ/Moochā€¦
now regarding the battery to use on the FT02S and EA01 ā€” these are what I think based on my experience with these 2 flashlights:
  • FT02S (quad XHP50.2 LEDs) can use a LOT of power (more than 20 Amps), so a (fully-charged) more ā€œhigh-drainā€ or higher-discharge rating (real rating by discharge graph by 3rd-party reviewers like HKJ) battery could give it the most brightness (in this case, a 30T theoretically could give a bit more power than 40T, which gives a bit more power than the T50). Although in real life, temperature control and other factors may make the difference small, but the capacity (runtime) should be thereā€¦ (higher capacity should have a bit longer runtime).
- EA01 (single XHP50.2) can also use a lot of power (a bit less than 20Amps), but most of the good 21700 batteries will probably just have a nearly similar effect. I would suggest a T50, but maybe another good 21700 battery like the G50 likely wonā€™t be too different in performance compared to the T50.
[quote=d_t_a]
Thank you very much for your support to vapcell
The power performance of G40 is similar to that of Samsung 40t, but the capacity of G40 is higher, about 4100mah
My MF01 mini could do with a K64. Wonder if the high capacity affects the lifespan of the cell.
VapCell 26650 6400mah 15A Battery. This is a step up in 26650 capacity. I see myself buying more than a few.
+1
If that cell underneath the wrap offers the same current specs like PowerLongBattery's PLB-55A cell (see Shockli 5500mAh or Keeppower 6000mAh), it would be really awesome.
At least I am most pleased to hear that 26650 battery development has not ended yet. PLB has given up producing the PLB-55A battery last year, so the only powerful 26650 battery left is Golisi S43 with only 4300mAh.
VapCell 26650 K64 6400mah
Is this available from US dealers? My last 26650 search didnā€™t see it.
is this really legit the capacity, i thought 6000mah was the max this type of size could hold ?
Theoretically itā€™s about 7100 mAh if using the same guts as a 3400mAh 18650.
