Does the Noctigon K9.3 have a different programming than the D4V2 and the KR4?
Greetings,
Does the Noctigon K9.3 have different programming functions than the D4V2 and KR4?
In my other Wang lights, (from off), the aux light functions are controlled by either a 7 click or a 7 click and hold. From lockout mode, three clicks control these functions.
For some reason, the above 7 or 3 clicks will not control the aux light functions. I tried resetting to see if I messed anything up (hold power while unscrewing tail cap), but it did not fix the problem.
Any assistance would be helpful.
Anyone?
Why do you push your post after only three hours? Solution is simple, it’s in the manual.
Yes, K9.3 has Anduril 2.
By default it starts in Simple UI mode. Get it out of Simple UI and the freedom you’re accustomed to will return. To do this, 10h from off.
This is your friend.
