Very smooth beams usually come from TIR while reflectors usually have some sort of hotspot. If you want to get away from a hotspot, you probably want a light with a TIR.
You commented right after I posted beamshots in my review of the SP35 so I figure you’ve seen those, right? I feel like it shows a pretty distinct hotspot.
Sofirn should consider offering this light with LH351D, although I suppose that creates competition within the product line. I am not interested in low-CRI EDC lights, but I would buy an LH351D version.
I originally considered swapping a LH351D into mine, but decided not too. Pushing a LH351D at 6 amps is past it’s peak and well past it’s sweet spot.
It probably won’t be anything revolutionary, but I ordered some 3V XHP50.2 to try in my SP35. I’m curious in the impact on raw output (lumens) and to see if it runs any cooler in Turbo (depends on how the vF compares vs the SST40). We’ll see. I know the beam will be ugly but I can’t help playing around.
Just curious, what is a safe sustained max current for an LH351D (assuming somewhat properly cooled)?
I tested tailcap current of SP35 (with a nearly full charged battery), and getting around 5 Amps max current consumption on Turbo mode (using a UT210E clamp meter), with a nearly full-charged 21700 battery. (although I’m not sure if the power consumption will vary depending on battery voltage for the SP35 — since it uses a buck driver.)
I got 2 units SP35, ordered at slightly different time (from 2 different official Sofirn online stores).
Was wondering why their beam pattern has a bit of difference.
The units looks physically the same, nothing that I can visibly observe that’s different with their head or reflector (I haven’t tried to get out their reflectors to take measurements).
As can be seen, the head/reflectors look the same:
but there is a slight difference in beam pattern:
The left side is a slightly newer SP35, while the right side is the earlier SP35.
The left side SP35 has a more solid hotspot, whereas the right side SP35 has a smaller hotspot, but the hotspot (or is it the corona) is bigger.
Marginally. According to djozz’s test it looks like at 6 amps, the Luxeon V has a VF that’s 0.1 volts lower. Probably not enough to make a big difference though. Lumen output looks nearly identical despite the Luxeon V being a 4000K LED. So if you’re going for a CCT change, the Luxeon V could be a good fit. You might have to modify the V’s 4040 MCPCB a little to accommodate the screw sticking up to prevent it rotating. I measured the stock MCPCB at 16.7 mm. Honestly, swapping for a different SST40 would be a much easier option.
I recently tried swapping mine with an 3V XHP50.2 just for fun. Lumens increased a little, but it also got hotter faster. I will say, I expected the tint shift to be worse than it is. On a while wall, I can see it but it’s really not too bad.
Odd that the 50.2 made more heat with a regulated driver. Do you have data of high on the SST40? I wonder if it just conducted it faster? Better mcpcb or thermal paste / clamping in your swapped setup? My best guess here is that the lower voltage of the 50.2 allowed the driver to squeeze out a little more current. Above 7A the 40’s Vf isn’t that low.
Update 1: For the moment, there will be no new discount code for SP35. You may save $ 3 upon orders of more than $ 30, that's what I was told.
Update 2: Stock of SP35 without ATR is getting low, so the odds are good to see SP35 with the new improved ATR anytime soon. Sofirn told me maybe in two weeks from now.
Update 3: SP35T (using a secondary, mechanical tailclicky) is in planning now. Sofirn wants to take SST70 into consideration. As this is a 6V LED it would require them to either develop a sophisticated buck-boost driver (if kept as a single-battery flashlight) or to adjust their new buckdriver from SF47T to work in 2S mode (6.0V - 8.4V) with a 6V LED and two batteries in a row. I doubt they plan to release a long-tubed SP35T, though.
