I find 2700K E21A to be fairly neutral outdoors. I only really notice the light start to get warm at 2200K. I prefer warmer tones outdoors to cut glare walking around others, and to prevent insect attraction.
Although the lumens is lower with these emitters, would you say it is still sufficiently bright outdoors? I’m on the fence with my next kr4 having the e21a (2700k) or the sst20 (2700k).
I have the sst20 2700k in a c8 style thrower and it is plenty bright, so I know 4 of them would defintely be bright. I guess I’m just hesitant thinking the e21a would be less then half the lumens…
The aluminum KR 18350 tube will not allow use of the clip. The TI version will, but on the KR1 the larger head will be bending the clip out and creating a lot of tension, but it is at least possible.
I have a D4SV2 on hold pending the emitter choice, I have them in XP-Hi V3 3A and SST20 but may try something different for my green version. Would be interesting to see the W2.
So I put a xhp50.2 in my Cu KR1 the other day. Let me just say, it’s an awesome all around edc. Copper is heavy but I like it, xhp50.2 has tint shift, but I don’t care especially outside. I know Hank prob doesn’t use the xhp50.2 because of lack of tint options and tint shift hence a not really attractive beam, or maybe there other reasons, but I’m putting a pic here for others who may be interested in doing it themselves.
Xhp50 on left, w2 on right. Both kr1.
Visually, it’s brighter and throws almost as far as my ft03 mini with xhp50.2. Also the tint shift is not nearly as bad in real life as it is in this picture, especially outside.
No. As it turns out, deep red and “regular SST-20 have different-enough vf that the deep red come on solo first, followed by the 2700k higher up in the ramp.
