Oshpark Projects
1808 posts / 0 new
Quadrupel
Quadrupel's picture
Last seen: 1 day 20 hours ago
FET+1 D4 layout with indicator led support on Pin3. Anduril compatible!
15mm
Order from OSH Park
Tom E
Tom E's picture
Last seen: 3 hours 38 min ago
Quadrupel wrote:
FET+1 D4 layout with indicator led support on Pin3. Anduril compatible! 15mm Order from OSH Park AMUTORCH E3S Order from OSH Park
Been looking this over but can't see pin #2 connected to a pad for the switch - did you run out of space for it?
I know there's not much room on a 15 mm, to say the least.
DEL has a good write up on his 17 mm FET+1 here. He writes these are the mandatory parts:
  • C1 10 uF
  • D1 diode
  • R3 100K ohm to eliminate unintentional flashing during mode changes
  • R5 4.7 ohm to eliminate unintentional Vcc boosting during PWM
C2 and the R4 47K ohm resistors can be eliminated
Quadrupel
Quadrupel's picture
Right, no space for pad , just connect straight to pin. Why not? LOL
Scallywag
Scallywag's picture
Last seen: 23 min 44 sec ago
For 15mm, we make compromises Smile
Might make it a pain to re-flash later
Tom E
Tom E's picture
Quadrupel wrote:
Right, no space for pad , just connect straight to pin. Why not? :))
Sure, I've done it before.
lumenzilla
lumenzilla's picture
Last seen: 1 hour 58 min ago
I tried to (quick) read the entire post to find FW3A switch board or contact board but couldn’t find any.
Is it still a rare part?
Tom E
Tom E's picture
Quadrupel wrote:
D10-D20-D25 Headlamp FET+1 Driver . Anduril Ready ! ;)) PCB from=From pcbway
Nice! I'm attempting to order from PCBWay - $5 + $8 e-packet shipping for qty 5, total $13. Decent price, no rush.
Looks like PCBWay has to do an approval on the order first. Thinking they will take PP. They also offer a ton of options - hoping the defaults are good for us.
Quadrupel
Quadrupel's picture
Take 10pcs – same price ! ;))
Tom E
Tom E's picture
Yea, I see that now - thought it didn't work before, but I was tweaking settings.
Unfortunately after the review, they raised the price from $5 to $15. Dunno - I'm re-submitting with qty 10, maybe I made a mistake before.
Quadrupel
Quadrupel's picture
¯\_(ツ)_/¯
Tom E
Tom E's picture
Ok, this time with qty 10, the price stayed the same smile. Looks like they give you choice of colors for the solder mask and silkscreen, but won't take the chance of changing anything now...
Transaction went thru! Also added a $5 coupon, figure it was for first time order, so total cost with e-packet shipping was $9, including a $1 PP fee they added.
Not Bad! smilecool
Tom E
Tom E's picture
Took a while, but received the PCBWay order today! It's 11 boards, ordered 10. Had to think what the boards were for, til I found this thread smile
D10-D25 headlamp...Of course!
deved
Last seen: 3 weeks 3 days ago
Hello guys, I am looking for 17mm linear driver based on Attiny 13a with added SMD diode (0603 size) and proper resistor to indicate “ON” state (torch is based on IR led wavelenght, so beam is not visible).
I am preparing a project for my friends and I need to add an ON indicator for a simple clicky switch style flashlight, so I a decided to simply drill a little hole to the tube in the driver spring area and let the light from the diode get through – I did this before with use of extra diode and resistor (not SMD) to the standard Nanjg 105c but I would like to have it neater “on board”.
Would be someone skillful able to help me by adjusting some of the existing projects? I need 7pcs of 7135 to be left (2450mA) on the driver. I will sure compensate your time spent on this…
Thank you!
d.
KawiBoy1428
KawiBoy1428's picture
Last seen: 5 hours 12 min ago
Thank you!
d.
If your using a rear click tail switch, why not just go with a lighted tail cap? It will go off when the light is on…will be lit when the light is off.. just a thought….
. Too Bad (Led4Power) Neven’s store isn’t open yet. He even had some that had LVP added to them. They come in different colors and you have choices of set-up brightness. I use them on several of mine and changed the resistors to decrease/increase the brightness of the tail cap switch….
KB1428 “Live Life WOT
deved
Thanks, but I would like to keep the indication as small as possible and the logic “switch on = diode lights” as well.
d.
Quadrupel
Quadrupel's picture
Courui FET+1
Order from OSH Park
Josen for young
Josen for young's picture
Last seen: 1 week 2 days ago
Support!
Wurkkos Directの日本担当メタです。
よろしくお願いします。
コラボなどのお問い合わせ:
beyondyoungmoon@gmail.com
Skylight
Skylight's picture
Last seen: 8 hours 33 min ago
The TA drivers apparently do not work with 12V or 4S battery configuration. Is there any FET driver on Oshpark that supports 4S?
Also, is there any board with two FET footprints like the Haikelite MT09R driver has it?
Tom E
Tom E's picture
The 7135's are the problem at 6V or 12V - they usually will either right away or eventually die. So, TA designed a driver with a bank of resistors to replace the 7135. So the 12V 4S battery TA driver with the resistor bank  should work fine. It's been well tested and shipped in production lights.
Haikelite is doing something similar to replace the 7135, but much simpler circuitry, so it works with Anduril for FET+1's (Q8 hardware config) quite nicely. Not sure who designed it, if it was Lexel or another BLFer, or Haikelite.
Of course with any driver over 3-4V you need an LDO instead of a D1 diode, but we've been using LDO's for years in OSHPark BLF designed drivers.
Should be noted we were getting away with FET+1 (single 7135) drivers with LDO's for lights like the L6 for years. For 6V and relatively low amps (single LED), the better 7135's seem to hold up but I wouldn't count on them lasting.
Skylight
Skylight's picture
Thanks for the nice explanation, Tom E. Thumbs Up
Tom E wrote:
The 7135’s are the problem at 6V or 12V – they usually will either right away or eventually die. So, TA designed a driver with a bank of resistors to replace the 7135. So the 12V 4S battery TA driver with the resistor bank  should work fine. It’s been well tested and shipped in production lights.
I know the TA drivers with resistor bank but I have never found them on Oshpark. Is there any possibility to get the PCBs of these drivers to solder them myself?
Tom E wrote:
Haikelite is doing something similar to replace the 7135, but much simpler circuitry, so it works with Anduril for FET+1’s (Q8 hardware config) quite nicely. Not sure who designed it, if it was Lexel or another BLFer, or Haikelite.
Does that mean I could flash the MT09R driver with the BLF Q8 Anduril?
Tom E
Tom E's picture
Ohh, yes, could be TA didn't publish the design for public access. Could be for technical reasons, but also it's probably only available in large sizes.
MT09R? Not sure. But I recently flashed the HL HK4S with Anduril2 and used a FET+1 configuration, same as the Q8, and it's working pretty well.
This is the HK4S driver:
and my notes on it:
That Q4 chip and associated circuit acts as a 7135.
Scallywag
Scallywag's picture
Of course with any driver over 3-4V you need an LDO instead of a D1 diode, but we’ve been using LDO’s for years in OSHPark BLF designed drivers.
Should be noted we were getting away with FET+1 (single 7135) drivers with LDO’s for lights like the L6 for years. For 6V and relatively low amps (single LED), the better 7135’s seem to hold up but I wouldn’t count on them lasting.
Would love to see oshpark shares of such designs.
Can confirm about 7135s in 2S config. My L6 has a fet+1 and works great (if slightly strange behavior – the 7135 channel actually gets brighter as battery voltage decreases). However, when I tried the same in my SP70, the 7135 blew nearly immediately. I need to reopen that light, remove the 7135, and reflash to only use the FET
Tom E
Tom E's picture
I've done exactly that before - FET only, but never got the low level output to ramp smoothly - didn't spend much time on it, so there's probably a fix, even if the fix is to eliminate some of the low level output levels. My modded 16X XHP50.2 6V light looked pretty cool on the 7135 at lowest moon, LED's just glowed, but the 7135's didn't last too long.
Skylight
Skylight's picture
Thanks Tom E. Is there any hex file for Anduril FET only?
Tom E
Tom E's picture
Not that I know of, but sounds like Scallywag may have one, soon maybe? I won't have time to build/test - been very bizy at work. In the past I did it with NarsilM.
Scallywag
Scallywag's picture
Tom E wrote:
Not that I know of, but sounds like Scallywag may have one, soon maybe? I won’t have time to build/test – been very bizy at work. In the past I did it with NarsilM.
Oh no, nothing I do is ever “soon”
The light has been like this since last fall…
Quadrupel
Quadrupel's picture
Lume1 with RPP and switch pad.
1
21.8mm
Order from OSH Park
22.3mm with switch pad and indicator
Order from OSH Park
CNCman
CNCman's picture
Last seen: 11 hours 8 min ago
Is it possible for someone like me with no electronic experience to build a MT09R driver for a new build ?
Skylight
Skylight's picture
It should be possible. It is not too difficult. You just need some solder paste and a hot air station or hot plate. Choose the right parts, put solder paste on the pads and place the parts on the board according to the parts list. When reflowing the parts usually position themself neatly. If I don’t use too much solder paste and the parts are not too close together I rarely need some tweezers to correct the parts position. Last step is to flash the MCU and solder wires and spring.
The only thing that could go wrong is a resistor or other part not being soldered correctly. That is what gave me some weird modes and blinking sometimes. And of course the parts are tiny. If something falls down chances are very small you will ever find it again.
2A
Last seen: 1 day 6 hours ago
I have built quite a few drivers from this thread and everything went well.
But I do have a question:
Which is the best DIY driver for a Convoy S2+ build with KW CSLNM1.TG ? I read many times that a FET might kill the LED.
I have plenty of spare parts, just need some inspiration which 17mm board to order at OSHPark.
Thanks.
