Can it be ordered without ceramical beads? Or at least less aggressive bezel?
Can modes be programmed differently? I mean e.g. 0.02, 1, 3, 4A are probably more like one low mode and three high modes. I’d like something like 0.02, 0.4, 1.3, 4A.
I just received the Jaxman M3 (xpl hi 2800k) and conducted some rough tests. I found abnormal noise when shaking when using the Samsung 30T flat-head battery. Using the camera, I found PWM in 1A. The overall quality is very good.
hi so many quesitons.
driver OD. is 20mm at present. while it can be enlarge in future.
the battery tube is 22mm inner diameter. due to all soft springs in both side, so the battery is not a problem.
No, no glue.
No ,not a PWM power adjusting.
We now have not other kind of bezel. while it is not a problem. we will made some without aggressive type.
Programing MCU scripts is too complex for me. I dont want do such kind of light. Never.ever.
Yes ,with memory function.
As Host, I think it is ok for BLFers for a small qty. mainly because it is too trouble to package, and aftersale affairs are also a main considering. We now are near to the Spring Festival of the traditional Lunar year.
Don’t take me too serious regarding your light, but I’d love if manufacturers would document which lines of the MCU do what. Makes writing a new firmware an option if in-system programming/flashing is possible. Documentation saves reengineering efforts and gives the manufacturers a selling argument.
Interesting light. Seems like the LH351D would be a better fit than the 219C, higher amps and higher output. I’m generally a fan of 3000-4000k so take that for what it is.
In fact the bezel is not a fat one. And we design ed the inner surface to be a very fit size.
And the reflector is 28mm OD. we think it is a propper size for a Max. OD 35mm flashlight.
But after all it will be fatter (thicker) than normal light . while just a bit of.
