The There Are No Stupid Questions Thread
1663 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 4 days 6 hours ago
Colonel Light wrote:
JasonWW wrote:
The UV leds can’t take much power so don’t mess with those.
It never produced much heat so I figured it wasn’t being worked hard.
JasonWW wrote:
What led does the S2 have?
According to the description on Banggood:
  • LG UV365nm LED 5W lamp beads are used.
  • The built-in drive is 7135×5 single file.
Sorry, I thought you were saying you had two different lights.
Colonel Light
Appreciate you trying to help. I have three in total: the S2 UV, an S2+ with 7135*8 driver and T6-4C XML2, and an S2+ with (if memory serves) a 7135*6 driver and a U2-1A XML2.
JasonWW
JasonWW's picture
Xml2 leds can handle up to about 8A. So you can swap the driver on them for sure.
The UV leds are not robust at all. They can not handle high amperage. So I would not swap their driver.
Maybe somebody that knows what specific LED is used can give us some numbers as to how much power it can handle. My guess is no more than 2A.
Scallywag
Scallywag's picture
Last seen: 7 hours 26 min ago
I’m not sure on the current handling, but if you search around BLF some you’ll find that all the UV LEDs can’t handle much heat, either. Even treated nicely they don’t have great runtime ratings. You can probably run them at 3A briefly and get lots of power – but, at least for all the examples I’ve looked at, you’re also going to need a 2 cells+buck driver or one cell and a boost driver to hit much current on them – the forward voltage starts high and ascends rapidly.
Starkm32
Starkm32's picture
Last seen: 7 months 2 weeks ago
Wouls someone please tell me how to post an animated gif for one’s avater? Doh
JasonWW
JasonWW's picture
I’m going to guess that you first need an animated gif that is no larger than 85 by 85 pixels. Then try to upload it in your account settings.
raccoon city
raccoon city's picture
Last seen: 54 min 52 sec ago
JasonWW wrote:
I'm going to guess that you first need an animated gif that is no larger than 85 by 85 pixels. Then try to upload it in your account settings.
Yes, and your avatar must also be under 30 kilobytes.
MoreHiCRILumens
MoreHiCRILumens's picture
Last seen: 8 hours 30 min ago
I got Sofirn C8F green for under 19 €‘s some time ago and thinking of modding it a bit. Got SS bezel coming which should fit it, but not sure what leds to get for it. I thought about sw45k’s, but would they work with this and how many lumens they would put out? I dont need max lumens, just to make it a really nice general use light.
Anything else I could do with this? Swapping wires too? Being a C8-model there should be a wide variety of different drivers and other stuff too? Lighted tailcaps? Open for all kinds of ideas and every bit of help is appreciated, thanks.
Colonel Light
Thanks to Jason and Scallywag for their input on UV LEDs (I left it as is).
I just recieved an Emisar D4v2 with 3500k E21A emitters, I was wondering if it’s “normal” for them to immediately turn blue on turbo with a high drain battery?
I’m assuming that it has the Noctigon driver which delivers 5A on turbo.
Rayoui
Rayoui's picture
Last seen: 7 hours 19 min ago
No, that is definitely not normal. I wonder if your driver wasn’t correctly flashed with the NoFET firmware.
Colonel Light
The LEDs are already burned, I think I’ll send them an email.
Templogin
Last seen: 6 days 5 hours ago
Battery question.
Some of my 14500 batteries have a “pronounced” pip at the positive end and some don’t. I know the trick of using a small round magnet to make the pip longer. Is there something different about these batteries internal make-up? Is there any reason that thay are not all made to a standard length?
Thanks
Boaz
Boaz's picture
Last seen: 6 hours 25 min ago
Usually there's
flat top
 button top non protected
 and then button top protected
I'd suggest a solder blob over a magnet any day .
 the thought of a possible loose magnet in a light gives me chills .
 you can do a decent solder blob in exactly  6 seconds ...Solves a myriad of length issues ..makes life enjoyable again .:)
Templogin
Excellent. Thank you Boaz. I feel an enjoyable life coming on.
Sarri
With my Olight Perun Mini, can I put one of those little magnets on the top and then safely charge it in a normal charger like my 18650s?
Pretty sure I can, just wanted to check…
lucifer
Last seen: 11 months 3 weeks ago
Has anyone ever made a flashlight out of these 250-315nm UV LED parts, or these 275nm UV LED parts? Or have a reference to a list of materials that can be successfully built and used in the 250/275nm range? Mod for a Convoy S2+ would be awesome but I don’t see a reference here or elsewhere.
Scallywag
Scallywag's picture
There are UV-C flashlights out there, but I can’t think of any builds on here (at least off the top of my head). If it’s anything like the ~400nm UV LEDs, then you can expect low power, high forward voltage (indeed, looks to be solid 2S territory on the ones you linked), and bad longevity.
If you’re planning a build, keep them within rated spec, make sure they are cooled well, get a constant current circuit at the correct voltage range, and make sure your optics are transparent to the wavelength you’re using (for example: polycarbonate optics block most of the normal UV light we deal with (back in that ~400nm range).
Oh, and use eye protection. Skin protection, maybe, too? I can’t remember.
For what purpose are you looking into a flashlight at these wavelengths?
Agro
Agro's picture
Last seen: 2 min 38 sec ago
Yes, you need proper eye and full body skin protection. I won’t advice you on what is proper (I was never interesting in using UV-C myself) but stress that UV-C is highly harmful.
lucifer
Just to do it, show off to strangers on the internet or friends. I’d try to build an x-ray flashlight if it was financially feasible, tho I see LEDs seem to bottom out well before x-ray territory. Probably different tech altogether and not a flashlight type of device.
EDIT: There are DIY x-ray machine builds available. Not a flashlight at all, but still feasible if you have some extra cash, time, and no concern for personal safety.
lucifer
ReactNation wrote:
Curious about your job and position? Smile I’m just looking for a job and now I am worried about this issue very much
About the feasibility of UVC flashlights?
Colonel Light
Why does a 21700 battery exist when a slightly shorter 21650 would fit into existing chargers?
raccoon city
Good question!
Oli
Last seen: 13 hours 34 min ago
Tesla and Panasonic thought it was a good size for their use. That was after using 18650s as other car makers did for many years. And now they’re moving on to the 4680. So yes nothing to do with flashlights or chargers.
You can't compare the big flashlight in the sky to the little flashlight in your hand.
Colonel Light
The 4680 looks large but maybe it could be an alternative to 4×18650 or 8×18650 torches/flashlights.
Skylight
Skylight's picture
Last seen: 8 hours 32 min ago
If I ran out of Attiny25 MCUs is it possible to use Bistro with clicky tailcap switch on an Attiny85?
slmjim
slmjim's picture
Last seen: 1 hour 54 min ago
Why do people chew applesauce?
slmjim
Smile! It makes others wonder what you've been up to.
Time is more valuable than money.
You can get more money, but you cannot get more time.
Scallywag
Scallywag's picture
It’s absolutely possible. You can’t go the other direction with some firmwares because the 13 and 25 have less flash than the 85 so for example anduril doesn’t fit.
I’m not sure what, if anything, you’d need to change, but I’m sure it can be done rather easily.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 26 min ago
I don’t get it. That’s a whole i1R or whatever in there, no?
raccoon city
Robin Dobbie wrote:
Has it been long enough since anyone asked why this doesn't work?
That flashlight should charge.
Your charger must be broken.  :P
Lightbringer
It’s not gonna charge. The light’s backwards. The pointy end goes down, and the flat end against the slider.
