Manker MK35 (White) Cree XHP35 HI 2550LM LED Thrower Flashlight Searchlight: $115 plus $18 shipping
See photos here: https://www.ebay.com/itm/184650489148
Shelf queen, like most of my lights. Tested but never used or carried. In like new condition.
This has been one of my very favorite throwers. If you like throwers, you'll love this one!
Features:
- One of the most powerful thrower flashlight on the market.
- Adopts latest CREE XHP35 HI LED with a lifespan of 20 years.
- Maximum output reaches 2550 lumens and super long distance of 1420 meters.
- Classical Manker interface gives different output levels.
- Lock-out function help to avoid accsidental turned on.
- Engineering Mode: Modify one comfortable moonlight you like for many possible.
- Swtich button, solid and more beautiful, retained Manker classical dragon breath function.
- Robust body with a stainless steel bezel make MK35 can be used for security popurse
- An ideal flashlight for search & rescue, hunting and law-enforcement etc.
Specification:
- LED: Cree XHP35 HI LED
- Max output: 2550 lumens
- Max beam intensity: 504100cd
- Max beam distance: 1420 meteres
- Working voltage: 11.2V - 16.8V (Overdischarge protection)
- Driver: Most efficiency constant current circuit
- Waterproof Standard: IPX-8 (under water 2meters)
- Impact resistance: 1.5meters
- Tail stand
- Material: Aircraft-grad aluminum body
- Surface treatment: Premium Type III hard-anodized antiabrasive finish
- Lens: Toughened ultra-clear glass lens with anti-reflective coating
- Battery: 4x 18650 (included)
Output mode / Runtime:
- Turbo: 2550 lumens (2550lumens last on 15 minutes than stepdown to 1600lumens) 2.5 hours,
- High: 1600 lumens / 2.5 hours
- Med 1: 700 lumens / 7 hours
- Med 2: 136 lumens / 21 hours
- Low: 47 lumes / 76 hours
- Moonlight: 0.1 - 5 lumens / 1500 hours
- Strobe: 2550 lumens
Dimensions & Weight:
- Dimensions: 188mm x 86mm (Length x Head diameter)
- Weight: 675g (without battery)
Package Includes:
- Holster
- Spare O-ring
- Lanyard
- User Manual
