Thank you Freeme!
According to manufacturer, the MT04 SST20 quad should do 4000 lumens, 650m throw.
Do you have link for this info? 4000 lumens sounds appropriate, 650m throw sounds like a lot. If this is true I will be ordering one. Im just wondering how deep those 4 reflectors are.
Thanks freeme. I eventually ordered a Blue XHP50.2.
I found the info on taobao site, it has some problems with proper loading: MT04
There were pics with both lumens and throw for all versions.
I did double check with BG rep few weeks ago. They have no intention of producing quad emitter version in EA01 body.
I found the info on taobao site, it has some problems with proper loading: “MT04”:https://item.taobao.com/item.htm?spm=a21wu.12321156-tw.0.0.7ab1771fNmuPIx&id=631647766191 There were pics with both lumens and throw for all versions.
Thanks for update Freeme!
Thanks for the link, very informative.
Beside ordering an EA01 i took also one MT04. Out of all the quad versions i found only the SST20 4000k high CRI really interesting. Other versions were too floody for me.
There is a rumor mention that they won't be producing any more MT04?
Did you base this off of the online photos? Or do you have other beam shots of the other emitter choices? The sst40 5000k quad really interests me
I am interested in a code as well.
Thanks a lot in advance!
Just ordered a blue one with SST 40 in 5k. Thank you freeme!
Thanx! Just ordered a grey SST40 5K
Interested in the SST40 version. Thanks
I talked to manufacturer as initially they had the SST20 quad version only on Taobao. He said that this version is discontinued, but he moved some last pieces also to his Ali stock. I took it because I have another much larger quad with throwy LEDs and I like its beam a lot, tight spot with decent spill. SST20 with 4000K and high CRI also peaked my curiosity, as I dont have any light with this LED yet. As for the other quad versions (SST40 and XHP50.2), they are still being offered, both at Tao and Ali as well. I just think that they are too much of a hotrod in such compact body, limiting its practical use.
Dioda, thank you for this info!
Big thanks for this info…Anyway,i dont see it still on their store on ali…Its still sold out.Iam interested for quad xhp neutral still…So probably we have to wait till the end of their holidays…?
Many thanks to freeme! I’ll make an order this week.
For those interested in the quad versions too, here is a video comparison between XHP50 and SST40: MT04 Quad
Very good video for those quad hungry one like me:) thanks
The way I look at it, if you want a quad, get the FT02S. EA01 has a wonderful beam pattern with the single LED and the TIR lens. All that goes away by converting it to quad.
