✌ ASTROLUX K2 300lm Keychain USB-C Flashlight
Preorder will happen soon.
Operation (machine translated)
In the operation logic shutdown mode,
  • Click to return to the stepless dimming memory position. Long press to enter the stepless dimming. Default minimum brightness. Long press until extremely bright.
  • Double-click to enter the burst flash Turbo position.
  • Triple click to enter the auxiliary function.
    • The light position defaults to uv/white light,
    • single Click to enter the red light,
    • click to enter the blue light,
    • click to enter the red light to flash,
    • click to enter the blue light to flash,
    • click to enter the red and blue alternately flashing
  • Four times to enter the voltage detection position
  • Five clicks to enter the locked position, and five more clicks to unlock
  • Six clicks to enter the RGB breathing light switch mode
  • Seven clicks to restore factory settings
10 clicks to lock and unlock kills the deal for me. :frowning:
There is absolutely no reason to make a flashlight without a removable battery other than controlled obsolescence.
Interested in one or two.
Two orange please.
I disagree with this.
What makes this style of light possible is the use of a pouch cells.
Advanced users will be able to replace them.
And you definitely don’t want regular users to handle them.
OK, they could in principle design an enclosure for the cell.
But then the light would be larger and very few users would buy a proprietary spare like this anyway.
I thought a pouch cell was flat like a pillow:
Would not you have to crack the case open top get it out? Where would you get a replacement? Are they for sale anywhere?
https://batteryuniversity.com/learn/archive/pouch_cell_small_but_not_trouble_free#:~:text=The%20pouch%20cell%20offers%20a,the%20highest%20among%20battery%20packs.
i like this operation. :+1:
wish it was a bit more like the tiki,
1 click no action
double klick to activate to moon.
but it is still way better than the lockout of the jetbeam mini-one
Pouch cell is any cell with soft enclosure. They can be flat or they can be thick.
Would not you have to crack the case open top get it out? I depends on how it’s built. In Rovyvon f.e. you can open the body without damaging it.
Where to get replacement? As usually, in China. They are less standardized then cylindrical cells, so getting the perfect size is harder though. F.e. 501030 cell as used in the 1st gen rovyvons can be found here.
Naturally you may also ask the manufacturer but they are unlikely to keep stock of fresh cells after several years (when your original cell wears down).
Interested. Probably 2 pcs.
Count me in for 4 please!
Interested (SST-20 high CRI and no PWM???)
Interested but I’d prefer it if the side emitter would be a very floody white high CRI one.
Please update my list!
Interested.
Done.
Interested in 2
Interested for 1.
Deal is alive now.
I have ordered in white. Thanks!
