Sorry I can’t help you right now. At “le moment suprème” the battery of my camera was empty.
In the meantime I would like you to refer to this POST where I tried to explain the build of my Fandyvoy (Fandyfire STL-V6 + Convoy C8). After charging I will try to re-take the left picture of the pill a bit better.
That post helps a lot. No need to take further pics.
Since I frost the lenses of my E17A flashlights to remove the donut holes, I don’t need to worry about focus. Does your technique work on E17As?
Too late
The blackened nylon ring takes care of the centering.
A shim around the nylon ring takes care of the focussing.
This shim I have cut out of the bottom of a yoghurt cup (indeed pushing the technology envelope).
Have no experience with E17A. Only XM-L, XP-L, SST40, SST20 and white flat.
I’m trying to put an attiny85 and Anduril on a qlite driver and am running into a weird problem.
I made a few mods on the driver so the 85 would fit. I got rid of the voltage divider resistors since the 85 gets the voltage right from pin 8. But the battcheck mode in Anduril would read very high and erratic voltage readings. So then I did some creative soldering to emulate the resistor and capacitor filtering that the D4 and D1S FET+1 drivers have, where there is a 4.7ohm resistor between battery pos and the diode, and a capacitor to ground on either side of the diode. This worked and the voltage readings were stable and right on.
I was still in the process of bench testing and getting the ramp table right when the driver stopped working. It would not turn on; only giving a small blink as the button was released. Disconnecting and reconnecting power did not fix it, but letting it sit for several minutes did fix it. However, it keeps happening after a minute or so of playing with/testing the driver.
I don’t think it’s anything in the code since the problem happens with unaltered code that works fine in my D4. I also tried a different attiny85 and the same thing happens.
Anyone know what would cause this behavior?
I think my issue is resolved. I had a hunch it was a power issue; that the attiny85 was getting voltage spikes or something causing it malfunction. I was bench testing using a power supply and using a battery, but both using relatively long wires. I decided to just put the driver in my headlamp and see what happens, and it seems to be working with no problems yet. I guess the extra inductance of the long wires led to voltage spikes?
Similar problems have been observed.
Last night I tried a Attiny85 on a PD68 Double-down 17mm board for the first time and couldn’t get the 0.1 uF cap across the MCU grnd and VC pins to fix the problem. Also adding the stacked 2nd 10 uF cap didn’t work as well. I’m testing the driver on the bench, even using a low performing under charged TF Flame cell, and the highest level modes don’t work, and strobe modes don’t work as well (strobe uses full FET). Not sure if it’s just FET full mode, or also the 30%40% 2nd high mode also. I’ll…
Glad you got it working!
Wurkkos WK01 with Nichia 219B sw45k D200 R9080 from Bob_McBob
Thrunite Ti3 AAA mod to N219b 3500k 9080 from azhu. Very nice tint imo
Ok, pinkpanda… do tell. How did you accomplish that?
I second that !! :sunglasses:
But that’s a secret recipe we may never know.
Damit 3 times I’ve tried to reply now. Work keeps getting in the way
It’s not that techy. You know I’m not good with code so I did a work around. I had an original fw3a with a lexel aux board installed (fixed colour). I removed the board and soldered this led in place - https://m.globalsources.com/LED-component/RGB-SMD-LED-1170310432p.htm
It’s the same kind of led l4p uses in his rgb tails so there is no control over the colours. The low brightness setting isn’t enough to light up the blue led when that colour cycles around but on the bright setting there is no problems.
I wondered if that’s what you did, but they seem to stay in unison. I figured with multiple LEDs they’d end up fading to different colors at different times.
I remember djozz trying out something similar with tailcaps. Now that I go back and look at it, it is pretty cool even if they aren’t synchronized.
Supfire S1 small 16340 tube light, fixed BLF-A6 driver with 460 Ohm bleeder, 219C R9050 SM353, switchboard with 50K pot under the spring, lighted ring with 3x 3.3 kOhm and 6x slow colour change 0805 rgb leds from ebay.
Fun is that the leds are not completely autonomous, they slightly influence each other’s timing and actions so that the cyclus becomes partly chaotic.
Yeh it’s lava lamp style with multiple leds out of sync.
The trick with this fw3a - i didn’t replace LEDs on the board rather I removed the whole board and soldered the control wires directly to a single rgb led. So technically it’s floating loose in the head.
I made a pair of S3 quad E17As 21700 flashlights - one with 2700K and the other 5700K. I got the S3 hosts from Kaidomain, the 6 amp drivers from the Convoy Store, and the Nichia E17As from Virence.
This time I used 26AWG Teflon wires (vs 24AWG silicone) which were much easier to solder to the VR16SP4m boards and to curl up into the driver cavities. The effective gauge (Wirebarn) of 2 26AWG wires is 23AWG, so good enough capacity given the 5cm lengths. I super glued the reflector spacers on to the boards to prevent any damage to the delicate E17As. The 2.5mm thick shelves do a great job dispersing heat which can be felt almost immediately when on high. There were some burrs on the shelf holes, but other than that, the hosts with included pocket clips and lanyards are of high quality.
The 21700 size is starting to push it for carrying in my pocket, but still acceptable. I had to frost 1 side of the lenses to remove the donut holes. The resulting beams have noticeable hotspots and the tints and outputs are impressive. So is the extra capacity of the 5,000mAh batteries. I’m torn as to which flashlight I like better, but I’m leaning towards the 5700K despite my tendency for warmer temps.
I made a pair of S3 quad E17As 21700 flashlights - one with 2700K and the other 5700K. I got the S3 hosts from “Kaidomain”:http://kaidomain.com/Flashlight-DIY-and-Tools/diy-flashlight-shell-or-flashlight-host/DIY-S3-21700-LED-Flashlight-Host-126mm-x-27mm, the 6 amp drivers from the “Convoy Store”:2.03€ 69% OFF|20mm Fahrer für SST40 ,12 gruppen, max strom ausgang 6000mA, Temperatur schutz management innen|Taschenlampen| - AliExpress, and the Nichia E17As from Virence. This time I used 26AWG Teflon wires (vs 24AWG silicone) which were much easier to solder to the VR16SP4m boards and to curl up into the driver cavities. The effective gauge (“Wirebarn”:Wire Combination Calculator) of 2 26AWG wires is 23AWG, so good enough capacity given the 5cm lengths. I super glued the reflector spacers on to the boards to prevent any damage to the delicate E17As. The 2.5mm thick shelves do a great job dispersing heat which can be felt almost immediately when on high. There were some burrs on the shelf holes, but other than that, the hosts with included pocket clips and lanyards are of high quality. The 21700 size is starting to push it for carrying in my pocket, but still acceptable. I had to frost 1 side of the lenses to remove the donut holes. The resulting beams have noticeable hotspots and the tints and outputs are impressive. So is the extra capacity of the 5,000mAh batteries. I’m torn as to which flashlight I like better, but I’m leaning towards the 5700K despite my tendency for warmer temps.
Great build!
Would you mind posting a beamshot?
Here you go. I’ve alway struggled with white wall beamshots since they never look as good as what I actually see, but I understand why people want to see them. I’m sure my next iPhone will be much better, but that may be awhile.
Looks great. I don’t see and donut in the beam. Can you confirm it’s not visible also in longer distances?
