Candela is somewhere too, but I do not remember where. Either in another thread or on Vinh’s site. But it is an amazing light with great throw and enough flood for most ordinary purposes in the woods.
Just got mine, I have the other flavors, none throw like this does; gives my KR 1 a run for the money with far more lumens via larger hotspot. KR1 is SST40 @5k.
I agree with OP, numbers on this would be impressive and helpful.
I only know he has it because I have been watching the D4sV2 on Vinh’s website for awhile now, so here is Vinh’s numbers for it with w2. These are by no means my numbers, I copied this info from Emisar D4Svn V2 - Balanced 26650 Thrower Light R - Sky Lumen
White2 5400K 4600L, 100Kcd, 633m
And from what I hear and read Vinh puts a lot of stock in the accuracy of his numbers and ratings. I would tend to trust his numbers over some manufacturers numbers (not necessarily Hanks, but other manufacturers).
And those numbers are incredible for the size of the D4sV2, and I believe they’re true.
It is the best led combination and light in Hanks lineup.
I have multiple combinations of each model and prefer warm tints, yet this light is just a killer.
Wow, this is good to know, I have been wanting this combo for months now, may just have to pull the trigger. My D4sv2’s are still among my favorite lights .
And on second thought, my d4v2 with w2 I got from Hank out throws (I’m pretty sure) my sst20 5000k D4sv2. so the w2 in the D4sv2 must be amazing.
Sadly, Vinhs number are sometime right but sometimes far from what others report. I wouldn’t trust them.
Here’s a post that combines all measurements that I found for a subset of lights:
The most extreme case there is stock GT Mini Vinh reports 170 kcd while 7 others got between 106 and 148.
^ good to know Agro, thank you for the info. I don’t own a light by SL, but will make note. I’m sure the plethora of ways to measure also must make consistency difficult. Just the fact that the customers varied from 106-148kcd, shows me the variance possibility is real. All good info though.
I’ve got a w2 D4V2 from Vinh. The numbers on his website are 3900 lumens, 45Kcd. It has been my edc for quite a while now. It outthrows my SST-20 D4V2 by a huge margin, and yet has an incredibly usable beam. I strongly prefer the tint and CRI of the SST-20 light, but the performance gap is too much to ignore and the SST-20 light just gets used around the house.
I have two of them from Vinh, and the throw really is amazing. At the same time, the beam width is acceptably wide, if not ideal, as a general purpose light.
I just bought a D4Sv2 W2 from Ariet this week. And yes, it’s awesome. I’m going to take some measurements tonight before tearing into it for reference points, because it’s going to get a set of sliced SST20s, possibly a mix of 3000 and 4000K or just straight 4000K - we’ll see. I’m gifting it this weekend, but I’m certain I’ll be getting another ANGIE light or two. Just the best beam characteristics I’ve seen so far. Even, wide and reasonably intense hotspot and a narrow spill with soft edges. Perfect IMO.
Hank… (clears throat)
If you are listening. I have a candid request. We need a KR4S.
ANGIE. 21700. Tail e-switch. Done. Top 10 all-time flashlight.
Angie doesn’t like sliced sst20s. I measured the exact same throw sliced to 1mm as I did with the domes (44kcd) Tint improved slightly, but not enough to justify the effort and lost lumens. There wasn’t any tint shift to start with either. A few minor artifacts also appeared. These were my last 4 good ’20s from MTN, so it will stay this way.
The W2s that came original were pulling a sweet 101kcd at turn-on. But the CW made it nothing but a toy IMO, and it’s lovely with the sst20s
