Its definitely unique. I have it set like this… tighten bezel=turbo, loosen bezel=low. I usually keep the bezel just a little bit loosened. So it starts off on low-candle every time, and If I want to activate a momentary turbo I just press the bezel with my thumb. No click switch required. Of course if I want a constant-ON turbo that requires 2 hands to fully tighten the bezel. It works for me. Others will dislike the 2 hand operation for sure.
However, for general use and, IMO, for most torches, I would suggest a selection of modes.
I mostly deal with EDC type situations, so I need a light that covers as many as possible, with the simplest possible UI. It must be one-handed operation, as I so frequently find I need light right at the moment when I have to keep something held in place (engine parts, PC parts, weapon parts, dogs, children) with the other hand. Most of the time that means a tailswitch.
Many normal lights can be pressed into service for a ‘tactical’ situation, which in non-tacticool speak means used to blind an attacker, in the one and only situation you’re likely to need it.
This means the strobe would need to be separate from the main cycle, still instantly accessible, but not in a way that is easy to trigger accidentally.
Otherwise, I hate it and would want it gone entirely!
Or any other mode, and for that reason I think any light that has Mode Memory should include the option to disable it, with the torch always starting on Low.
I think there would come a point of diminishing returns, though.
For most EDC, I would suggest 1,000lm as a turbo and perhaps a High of around 2-300lm, Medium about 50-100lm and a Low somewhere further down around 15-30lm… I’m thinking mostly of battery runtimes when not blazing like the sun, so even with 4000lm Turbo, would you really use the 500, 1000, 2000 sorts of levels?
I really like the TK11 TAC method of a switching collar. It allows one-handed use, provides a physical lockout, and you can switch between two different modes (Low-Mid-High/Strobe, or High/Strobe). The main switch still gives you momentary and on, with hold for Strobe, but really you could have several mode sets, each neatly separated, simply laid out and readily accessible.
I’m also a fan of that, although I am very partial to Nitecore’s LCD screens!!
I agree in part… I think high level blinkies are too dangerous for the average human to have, and *really *bright white/yellow lights belong on dedicated rescue strobes only.
However, I use the red blinkies on my LD15R on a very regular basis for work, as a safety marker. For a light that people EDC in various situations, that will include emergencies (usually vehicle based) where a low-medium brightness red or orange beacon would be of considerable use… even as a ‘just in case’ feature.
Other colours may also be of use, depending on the country.
Simply holding the switch long enough seems to work, for the most part. But again, a switching collar could do all that.
The question and choices is sort of trying to blur the lines between the UI and modes and there’s no reference to Turbo at all. Ramping is good. It’s got to have moonlight and it’s got to have turbo and a fairly quick and easy way to get to both of those for EDC. And of course it has to have mode memory. If it doesn’t have ramping it’s got to have at least five modes. Moon, low, medium, high, and turbo.
I dont like the overly simple UIs like on my convoy 3/5 modes with the strobe/sos in the main rotation.
I tried very programmable lights with Anduril and found those overly complicated, with too many functions to memorize and had a fear of messing up the settings.
I find my favorite lights have something in between. The Thrunite T1 is one of my favorite EDC UIs. Click and hold moonlight, click on/off then hold for ramping. Double click for Turbo, Triple click for Strobe. Let the factory set the temperature limit to throttle turbo, LVP etc. I dont want the responsibility. Oh and a little led in the switch to alert me when battery is getting low is nice.
Menu 1 for a gentleman's pocket light, where starting on Moon (or low) is advantageous for reading a menu in a dimly lit restaurant for instance.
Menu 2 for a service/utility light where starting on H is convenient for observing under vehicle hoods, inside wiring closets & such, where H is most useful.
1.) Instant access to turbo
2.) Instant access to moonlight
3.) A way to disable mode memory by ramping from moonlight to low (severely lacking in many lights)
4.) Strobe should be a hidden mode - personally never found a real life use for it
5.) Moonlight, low, medium, high, turbo
I like the ability to on the fly change any mode into anything I want it to be . Old Archeon driver is the closest thing I’ve ever seen to it . Downside was it was two modes fully programmable and sos strobe . Upside is you could just shut off the light and it would start in the first mode you just set ,skipping the sos / strobe ..... i’d Make it a three mode and drop or hide the flashy stuff . << perfect .Simple ... easy to learn and change in seconds .
Not quite sure what to vote here. For my own use, I really like a UI such as ZL or AT uses with direct access to lowest, highest and memory/middle mode. Anduril fits here as well. For more of an emergency light (first responder, structural fire fighting, tactical, etc) I want simpler- maybe 1 mode or low-high. And a general purpose light for loaning or family use? Well the L-M-H simple UI is hard to best….
Love the magnetic control rings for smaller lights
1 mode for when I'm out in the middle of nowhere doing beamshots at night.. If I hit that button 1 or 100 times, I know it will have 1000 lumens each and every time, and not accidentally hit a progammable mode. When your life depends on a flashlight, you don't want to have programmable modes.
That would be ON-OFF
Always comes on in correct mode and never needs re flashing.
Doesn’t need a manual or grandkid to explain it to Gramps
With protected battery does not need LVP, when it dims Recharge it, if it shuts off-Recharge it.
Perfect
Programmable all the way. If you program your light yourself, you can program to whatever way you want it to behave. Single mode? Can do. 3 modes? You got it. Blinky modes? Pick how you want to access them. Ramping? Sure, why not. More options is ALWAYS good, you can just not use them and program your UI to not feature them
Of course, you need a UI suite that gives you all these options to pick from, but that’s a given for anyone that ain’t a muggle.
I voted other. Could have voted programmable or 4 mode just about as well. As others have stated: Instant access to moonlight and turbo along with a memory works well for me. Love Andruil. However, not sure appropriate for gifting. Thrunite and AT do a good job with UI and I very much can live with those. Different lights different needs so Andruil wins. However, Something like the Manker or AT lights with the adjustable moonlight really is preferable but I think that is a hardware and UI issue.
I just saw this on Simon’s AX Convoy store, for the ramping M3-C mode selection / UI. I think this is pretty close to perfect for me. Simple and nice options. From the listing
Mode operation instructions:
1.click the button ——> flashlight is turned on with last brightness ——> press the button,brightness ramping up ——> release and press the button again,brightness ramping down
2.flashlight off, press the button ——> moonlight mode 0.01A (0.2%) [This brightness will not be remembered]
3.flashlight on or off, 2-click the button ——> turbo 100%
4.flashlight off,3-click the button ——> strobe
5.flashlight off,4-click the button ——> tactical mode, only 100% ,4-click the button again to quit tactical mode.
6.flashlight off,5-click the button ——> voltage detection (* means “flash” , * pause* means 3.7V, )
7.flashlight off,6-click the button ——> normal ramping mode switch to 4modes 1–10–40–100
8.flashlight off,10-click the button ——> Lock mode,The flashlight will flash once under any operation, which means the flashlight is locked.10-click the button again to quit lock mode,Please note that this is the only way to unlock.
Despite my attempts to make a “universal” interface, I think the UI really needs to be tailored to each light… or at least, each category of light. Change the hardware, and the “best” interface changes too.
