For 4 modes, I'm think'n mode memory would be better. Not sure why they dropped it, since the MK-I has it with only 3 modes.
Not crazy at all bout the clip - it's not a keeper, to lose, spins, etc.
Magnets are a great idea for the tail! I was think'n of sanding.grinding down the tail end and lose the lanyard holes and mount to get it even smaller, but probably won't do it.
Sand it down, super glue a 1/16ā x 1/2ā disk magnet to the back and PlastiDip the rear end and you will have a shorter magnet light. Some good thin cord would make a decent lanyard around the clip grooveā¦
A neck lanyard connected to something like this might be useful. Need to find a swivel loop with shorter threads so it would sit flush. Add a drop of blue locktite to secure it. This II MK is light weight enough to wear around your neck.
This particular swivel is made to attach to a camera
Been more than a few comments regarding lack of " mode memory" on this light as the ui always restarts on low. After a bit of use I find I kinda like it. It's an edc, jack of all trades light and it just works. Running EFest 700 mah V2 and it's replaced my 3 yr old Olight i3s EOS as it is superior in all aspects except size. That isn't a negative for the JII Mk as it uses the added size well. I use the light very often but usually not for extended times on high. After a week the battery still reads 4.06v and I cant find fault in that either. I also have the Jet I Mk and Jet Ī¼ but haven't given any pocket time to them as the J II Mk does everything I need. Good edc, should be in everyone's rotation (if they do such things).
Thatās a great idea, and one I may well borrow. Iāve got a few camera odds and ends knocking about so may give that a go.
The magnet idea sounds like an interesting one but one of the biggest selling points for this light (so far) for me is just how light it is. I wouldnāt really want to mess with that too much; but then I donāt know how heavya strong enough magnet is.
Also surprised and disappointed that there is no memory function for the JET-II MK!?
I have the JET-Ī¼ and JET-I MK lights, both have memory function which is extremely useful! It saves having to cycle through brightness modes every time you want to use the light at a specific brightness level.
With four brightness levels available on the JET-II MK light, I would have thought memory function would have been almost mandatory. But because there is no memory function, every time you want to run this light at a specific brightness level (apart from the default level), it means having to cycle through brightness modes until the brightness level that is wanted is reached. Not convenient!
Was considering getting the JET-II MK light, but as it doesn't have memory function I won't be getting this light.
Wow, no mode memory, that is frustrating.... on the other hand, the Olight i3s, which I like a lot, doesn't have it either, so maybe that is not that mandatory for me... the fact that the jet ii mk starts in low mode is a plus, the i3s starts in medium, which is bad if you wants to use moonlight mode and preserve night vision.
Iām so used to sticking all my multimode lights on low/moonlight/firefly, whateverās lowest (to keep from getting blinded in the middle of the night), that nothing ever struck me as being amiss.
Iām okay with it. My only gripe, if you can even call it that, is that itās pretty hard to crank. Definitely gotta 2-hand it, unlike most other twisties I have.
And is just mine, or is the pocket-clip free-spinning in orbit around the II? Doesnāt help when trying to grab the baseā¦
Other than that, I quite like the II.
ā
Hey, anyone ever non-destructively take apart one? I definitely want to swap out the emitter, but dunno if itād go boom if I tried.
No dome, looks like an XP-L HI, so thatās at least good.
No idea whatās TSG, well, I know what itād be used for, but not what itās made of, etc.
All my Jetbeams were really nicely lubed, not scratchy or gritty at all. When I do need to lube a light, I got this YEZL stuff from FT thatās nice and waxy in the jar, thins and liquefies on your fingertips, applies nicely.
Lotta people like Nyogel, etc., for their lights, but I donāt have any experience with that.
Just make sure whatever you use is compatible with the O-rings on the beastie.
Thanks LB. Tried sussing out the composition of the slide lube. Canāt find out much, so I wonāt tempt fate.
I will check out those suggestions. Cheers, mate!
This Jet-II is requiring a surprising amount of two hand force to turn on. Just wondering if a fresh lube coat will ease it up a bit.
Yes, the lube gets thicker over the time. Maybe dust. If used as EDC, it needs regular service like most or all twisties.
Edit: Btw., a 17 mm driver with button +contact fits. I onced used one of those 8x7135 drivers with mode memory. Think it was an old Convoy driver. Bezel is not glued.
If itās too easy to twist, it will have some longitudinal play, resulting is less precise switching, means even more bouncing through the modes. I find twisties very difficult to adjust/operate. Doesnāt matter too much in normal situations when the light jumps a mode too far, but if you rely on your night vision and absolutely want firefly mode (which is nice on this light), a twisty is not a good choice.
Edit: I forgot - when the light was in stock for too long, maybe the o-ring grew a little. Thatās another problem. There must be a replacement o-ring in the package you could try.
