Woah, that absolutely blows away my Hue Ambient, which are about Ra 83. Thanks for the tip, just ordered 8 to try. Love the Duv at 3000k, as thatās my go-to interior light.
Sunlike, have you considered Nichia V4 COBs?
According to my rough calculations, when underdriven they should deliver close to 140 lm/W at 85Ā°C with CRI 9580.
TIL Citizenās primary business is LEDs, very interesting!
Suppose their watch brand is more of a holding of the larger company like how āSeiko Epsonā owns the Seiko watch brand as a tiny sliver of everything else.
Interesting! I've been trying to keep an eye out for (reasonably priced) home lighting products made with their new Thrive lineup. My ultimate would be a zigbee-controlled CCT/dimming option. It looks like their Vesta series does 2700K-6500K, though frankly I never use above 5000K.
Where should I keep an eye out for more info? @bocian
They are in PL as well. I considered them until I saw some CRI97 lamp (or bulb?) that they claimed to make over 150 lm/W at very low price.
I donāt trust their ratings and I wonāt buy them.
Iām shopping for similar lightsā¦and I chose to go with simple lights that are based on E27 bulbs, either for all or for most rooms, not sure yet.
The reason is that:
The part that fails from time to time is inexpensive and easy to replace
Thereās a lot of choice of CRI97+ bulbs as well as bulb-based fixtures, but nearly all fixtures with LEDs have just CRI80
I consider some of the bulbs that over-saturate colours for the dining room, good luck finding one with LEDs already installed
Though I like how the diffuser is uniformly lit in LED-based fixtures. And for that reason I consider buying a fixture and filling with LED strips. Though itās more work, not so easy to replace (still quite OK) and actually there are fewer good strips than good bulbs.
I am thinking to implement it the same way as there are some options on E27. The downside could be that the light is not evenly distributed as with the integrated LED. I am also not sure how the diffuser will affect the CRI.
Maybe I will conclude on buying some E27 Sunlikes in combination with any of the options above.
For the rest of the installation I plan to buy some GU10 Philips ExpertColor (or Sunlikes on GU10 adapter, but donāt like the adapter idea). Another option is GX53 Sunlike - SunLike5-8 GX53 ŃŠ²ŠµŃŠ¾Š“ŠøŠ¾Š“Š½Š°Ń Š»Š°Š¼ŠæŠ°.
I chose to go with Lidlās Livarnolux for the bulk of my bulb needs. But I have some uses for better bulbs as well, these will be filled by either Sunlike or Bocian.
Below is my latest product (Bridgelux THRIVE 7W GU10 TIR optics) . Sorry, but I am quite a busy man and currently do not have time to translate. I will make a description in free time and maybe send some samples to Maukka https://www.swiatelka.pl/viewtopic.php?f=57&t=25080
