Couldn’t agree more, a certain light is closer or not to the perfect light depending on your expectations/what you wanna use it for.
When I want to light up things in my narrow garden, I want as little spill and quite a narrow beam, so I don’t annoy my neighbours. For that, my L21A is much more suitable than my FT03, even with the SST40 on it.
After further contemplation if I lived where you did or near or around the city.I would still want more throw.It would compensate for how the light pollution diminishes the beam intensity.I have seen many beam shots on here and other forums that have done nothing for me because of all the light pollution.I am grateful for where I live for that and many other reasons.
There aint a thing as too much throw, otherwise people wouldn’t buy LEP lights.
Its just that there isn’t just one perfect flashlight.
You need a dozen of lights to select from, to suit your actual need
Agreeable. After a certain point, the human eye can’t even see as far as the pencil beam is being output to, so there’s really no point other than bragging rights about spec sheets.
But what exactly is that certain point? I’d say my vision while not 20/20 is pretty good and I can clearly tell the difference between a 1km and 1.8km light. The rating just means it’ll be as bright as moonlight at the stated distance which in other words means it’ll be useless at the rated distance. For real world use I take the rating and divide it by four to get a more realistic rating. If the human eye can only see 1.2km, then you’d need a light with about 4.8km of throw to actually see things clearly at that distance. I mean you’d probably be able to see things 1.2km away with a 3km rated light but it’s not gonna be very useful at that distance.
When your battery charger is on fire and your cells are venting, but you can’t smell the burning through the fishy stink… then yes, you definitely can have too much p*y!!
I hate LEP lights, but if indeed throw only is your baby, then those would fit the bill. But those who want normal effective illumination would NOT be all-throw in preference.
Can’t see ‘what’ further then 3/4 miles away? I can see the moon just fine but i can’t see a neutron that’s right in front of my face.
Too much throw for a specific situation is a thing and i get that the OP is talking in relation to his own personal use, but there are situations other than for bragging rights in which throw is useful.
I also get the sense that sometimes throw is confused with hotspot size, or the relationship in brightness between the hotspot and spill i.e beam pattern.
One can reduce the throw of the L21A by using a mode with reduced brightness but it still won’t be comfortable to use as a walking light.
Useful review for me though Chicken Drumstick, nice to see the L21A beam in relation to the FT03 beam. I have a sliced XHP50.2 in my FT03 which seems to be a cross between the SST40 and XHP50.2 standard beams,.
