Awesome news Matt!
My first thought was “Holly hell!! He’s bringing Gatlight back!!”. I remember playing with those at CPF meets and night hikes around ~2007 time frame. IIRC they weren’t 240 OTF though, and most certainly not that when you factor in the heat from extended time duration. Good times!! We had calibrated initegratinig spheres at those meets where I learned NONE of my lights were really all that I thought they were… including my malkoff M60 / 6P.
Good Luck with the new company. I have no idea who owns the copyright on “Adventure flashlight”… my guess would be Ozark Trail (walmart company brand).
Woo-hoo, how exciting, Matt! I have to say, when you were showing the UI I was kind of thinking “meh” until you got to the ramping, which I really like!
If you ever roll out a good rotary switch, that would be great too. But I’m sure you want to keep the investment manageable for a while. May your endeavor be blessed!
I dont’ recall, that was a long time ago. To be perfectly honest I never really found the ringy XRE beam pattern all that troublesome. Many people did however, so there was never a shortage of both smooth and OP reflector options.
Thanks Matt, always enjoy your videos and found the history lesson along with your quest for an available trademark interesting.
I have nothing against simple interfaces, but the behavior of "immediately after turning ON, one click for Low, two clicks for High" does not seem ideal compared to something more like this if possible:
One Click from OFF for Normal Brightness
Press and Hold from OFF for Minimum Brightness
Double Click from OFF for Maximum Brightness
Press and Hold while ON for Ramping Brightness
One Click while ON to turn OFF
I believe this is preferable, because from OFF, you can directly access your desired brightness level and then fine tune it with ramping if required.
