Thanks! :innocent:
no problem… I corrected my commentary above though.
Oh, and make one with a 21700 form factor too!
Yes Please!
Thanks Matt, always enjoy your videos and found the history lesson along with your quest for an available trademark interesting.
I have nothing against simple interfaces, but the behavior of "immediately after turning ON, one click for Low, two clicks for High" does not seem ideal compared to something more like this if possible:
One Click from OFF for Normal Brightness
Press and Hold from OFF for Minimum Brightness
Double Click from OFF for Maximum Brightness
Press and Hold while ON for Ramping Brightness
One Click while ON to turn OFF
I believe this is preferable, because from OFF, you can directly access your desired brightness level and then fine tune it with ramping if required.
Good luck, Matt, and keep up the good work and the Good Word!
To be perfectly honest I never really found the ringy XRE beam pattern all that troublesome. Many people did however, so there was never a shortage of both smooth and OP reflector options.
Yeh, my old River Rock (Target house-brand) 2×C light uses an OP reflector with an XR-E, and it’s a pretty nice clean beam, no rings anywhere.
This looks like a great idea Matt. I wish you the best in rolling this out.
This looks PERFECT. Lights such as Wurkkos and Sofirn just don’t really do it for me as far as recommendations. Can you use an LED that is reasonably high CRI and decent tint? (Basically no cree LEDs fit that description ) Keep up the good work!
I see lumencraft.net still exists, but if you try to order from them it says their merchant account has been closed.
it seems to me unnecessarily long (what is going on in the driver that it has to be so long?)
and why does the head have to get bigger? the lumens are low, it shouldn;t need heat sinking…
you have a pretty concentrated hot spot, so maybe you need a conical reflector for that
but i would rather it be TIR and more floody - anything to make it small enough for pocket carry
to me, it is too big
if the main thing you are selling is the simple UI, why does it also have to be so big?
wle
Hi Matt, very cool, congrats Been watching your vids for ages.
I would like to echo the request about your font. I reckon the lights will look better with a different font.
Regards
Good Luck Matt
We are looking fwd to your new lights.
Good luck!
Congrats Mr.Smith!
i like reflector. It reminds me of old incan glory days when Fivemega made bottom part slightly OPish to remove artifacts while retaining good throw.
well done
Awesome
I think you are a Luxman
Please put a LEP Modul 500 Lumen or better
in a real big head 150 mm inner Diameter.
Dimmable in both directions,
Please send the first to me,no anodisation please
Regards and best Lux
Xandre
Great story-Good Luck.
Thank you sir .
I know there is a need for these lights .
I like simple on / off interfaces . I never give non-enthusiasts multi-mode lights .
I will wait for a one mode light that has a lit button with green for charged and red for ‘charge me now ’ .
The cable will say ’ Flashlight ’ on it somewhere so you can find the damn thing in the drawer with all the cables in it .
To please the enthusiasts it will also need a high CRI neutral tint and no discernible PWM .
That would be a light anyone could use .
P.S. You could actually call this ‘Dad’s favorite’ .
I’m quite sure it would be to me .
My wife too.
Interesting reflector.
But please, no Micro USB in 2021…
I noticed that also.
Awesome! Congratulations on the TM acquisition and looks like a really nice muggle light, or just a simple light for an enthusiast looking for a turn on and go deal. I like that you included ramping, almost reminds me of the Solarstorm SC01 I have with hidden ramping mode. Looking forward to more lights, and I am sure this is just the beginning.
