Depends on occasion, I generally have a keychain light been rocking the TIKI for a bit and it works well. For a pocket light if its just a regular day etc my trusty BLF A6 with pocket clip fills the EDC roll, if I’m say going to a wedding or a function where I need to be in a suit a Lumintop IYP365 would be the carry for the day.
front right pocket
OCCASIONALLY clipped to belt loop
Clipped inside left front pocket. I'm a righty, buy use my lights left handed.
Front left pocket. I’m a righty too but but front right is reserved for something more tactical.
Same. Knife is in the right. Non dominant hand for the light.
I wear bib overalls year-round. Lumintop EDC18, clipped in left bib chest pocket.
Almost always have a Tip attached by a retractable badge lanyard to a belt loop. Often have a sc31 clipped in the right rear and something else floating around in the right front….just cuz
ht on my neck.
Initially I would use a paracord, but now I use shock cords as these turned out to be more comfortable.
Though for the past 2 weeks I EDC another light as well, clipped to my pocket. I don’t think I’ll resign from a pendant because I don’t always have pockets - but I do like the ease of taking a clipped light out.
I also tend to have a larger light, typically a compact thrower, in my backpack.
I may end up carrying 3 lights regularly…
Oh, good, so I’m not the only weirdo. :laughing:
No… but you are still a weirdo!!
At least not for that reason, though.
Keyring. Sometimes need some light when doing a tracheotomy with my Klarus EDC scalpel.
Edit:
I noticed this omission, too. Glad you asked.
I made microcord lanyards for my i3E lights hanging from my keychains… So, I must vote for lanyards! :-)))
I voted for “other”, for the following reasons:
- Keychain: Rovyvon Aurora A8U with split ring
- Wallet (Arc Bolder): Olight i3T EOS clipped to the wallet
- Pockets (depending on the occasion):
a) during the day, RovyVon A23 clipped to the side pocket or the “cargo” pocket, on the left side;
b) at night, when going for a walk with my girlfriend, Olight Warrior Mini, clipped to one of the side pockets, mostly on the right side, next to the knife (left hand is for her ) ; if not for a walk with her, the light goes on the left too, and the right is for the knife
I voted for "Clip".
Light in left front pocket, knife in the right. Been carrying that way for the last 11 years, with 11 years being when I started carrying a flashlight every day. Have carried a knife every day since the early 90's.
I've carried the ZL SC62w every day, for the last 6 years. The SC64w above it is for backup.
The FW3A is a recent acquisition, that I've been enjoying quite a bit.
Just a good clip into my jeans.
Holster for me. I usually have the same type for my light, my multitool, also works well as a mag or baton holder. The clip, cannot be accidentally removed from the belt, and there is a swivel, with firm detents . The elastic sides of the clam-shell, have prevented everything I’ve ever placed in the holster from falling out, even when running. One of these:
They can share. Wallets don’t wear the ano either.
I don’t know about sharing. Wallet is already big and bulky so light goes to right, right next to the keyholder which is like a taco that hangs in Key-Bak and wraps keys so they won’t make sound or poke through pockets.
Ain’t it hard to get wallet out without light coming off with it?
I don’t have a problem with it. My wallet is medium size so maybe that helps. Usually the D4 rides at the bottom of the pocket, sometimes at the side vertically. This is when I’m not working. When I’m working, a knock around light shares that pocket with my keys. Ano be damned. Wallet gets moved to another spot. Sometimes my only light is a keychain light sharing a pocket with the wallet. All depends on where and when and what I’m doing. Always in left pocket though.
I’m holster all the way. The only exception is my little Olight S1 baton, which usually gets clipped on my shirt somewhere once in a while.
