FREEME ✌ ASTROLUX FT02S 4*SST40 / XHP50.2 26650/21700 USB-C Flashlight Group Buy - Ended
Freeme's Coupon: Request in this thread
Can I get the coupon code (XHP50.2 version) please and thank you.
Yes you’re right. When the EC03 caught my attention the black color XHP50.2 6500k was available and I assumed the green color was out of stock. I know now it was never offered. I’m kicking myself now for not getting the black one when it was available.
The petal effect is expected and I see that to some extent on all of my multi emitter lights. My FT02S beam when viewed on a white wall or ceiling at 1.5 m away is kind of a mess with the darker then usual band/ring of tint shift outside the hotspot and the unevenness outside that. The band shows outdoors, the unevenness not so much. Yes, I believe the proximity of the LEDs is the cause, maybe not the proximity itself but losing the inside walls of the individual cups due to the closeness of the LEDs. A member here mentioned it was probably a design decision to increase throw but it seems the depth and size of the cups have more effect on throw then the proximity of the LEDs. It is interesting to compare the FT02s to the Haikelite HK04 with it’s more widely spaced quad XHP50.2 emitters and similar output.
Anyway, I took the FT02S on a walk a few days ago and it’s fun to use.
Interested in XHP50.2 version. Coupon still available?
And one coupon for me please.
Ordered the SST40 5000K version in green, after stumbling across this thread last night.
It should serve well as an all-purpose camp light for me and the wife, here in the Ozarks.
Thanks for the coupon code!
Can i get code for xhp50 version please
Order placed for a green xhp50. Thanks for the coupon.
Sorry for waiting.
4*XHP50.2 code please green or sand
No worries. I was told I need to repost.
Forwarded.
Hi, I’m interested if possible in a coupon, thanks.
Also, is there a recommended holster for this flashlight? It needs to be belt and/or Molle.
Appreciate your help!
Could you send me a code as well, also if you have for s43s too. thank you
Hi, I have the Ft02s and this convoy holster fits it perfectly, better then any other torch/holster combo I have beside the ft03 setup. I have a holster for 80% of my lights and have tried numerous brands and sizes to find good matches.
US $4.17 | Holster / Cover / Case for M3 M21C M26C
Can I please have the code for sst 40 version. Thank you!
Thanks for the heads up!
All replied.
From where you will take it??as i know theres no source for xhp neutral right now…
Banggood has a couple sand colored xhp 5700k. Closest to neutral there is in ft02s…
