Artiet59, did you already notice my chart here?
https://budgetlightforum.com/t/-/62656/591
I could not manage to make it "straightforward", though. :-))
To me, it’s pretty similar in it’s day-to-day usage as V1. A few notable differences:
You can also access momentary turbo directly from on with 3H, provided the light doesn’t have tint ramping or two channels (like the K9.3), as that also uses 3H.
Lux-Perpetua - thank you, that is perfect! I will study it. I didn’t see in the advanced UI the commands for basic on/off ramping, etc. Is that explained up too in the “simple ui” section, in light gray?
GChart- thank you as always, I appreciate the highlights and that will be a good starting point for 90% of my use. Only thing that kinda is a bummer is accessing turbo… outside it is often nice to go from “midramp” or so to turbo and back easily. Not a huge problem, just not ideal I guess. Especially since I have no knowledge whatsoever on how to compile files and honestly I don’t know what that means…
Thanks Rayoui!
I finally flashed one of my FW3As to Anduril 2, and I’m really liking it, other than the fact I can’t access turbo in simple mode. It seems like this should be a flag in the ramp config rather than permanently locked out, especially since you can still set the ramp ceiling to full turbo. Simple mode is almost exactly what I’ve always wanted Anduril to be from the beginning: a fully functional light with all the extras and config menus hidden in a way you will never access by accident. I just really wish I could set the ramp behaviour to be exactly the same as advanced mode. Has anyone tried a build like this? Reviewing the code, it seems relatively simple, but adding the extra flag to the menu would be more work.
Yes, the UI section in the top part displays both SIMPLE UI and ADVANCED UI. The light gray lines represent the access to turbo that is restricted to ADVANCED UI only. I am still working on a nicer chart in a scalable vector graphics file format (SVG). This one will probably divide SIMPLE UI and ADVANCED UI, hence hopefully it will be easier to read and understand (fingers crossed). I also try to emphasize how to handle configuration menus as it differs from Andúril 1.0, e.g. thermal configuration.
Just wondering why there’s no setting to enable turbo in the Simple UI?
It makes zero sense to be able to change the max ramp to turbo and leave out a setting to just enable the regular turbo. Having to do this then eliminates lending the light to a muggle without having to reconfigure the max ramp.
There’s a heap of people that want to be able to use a flashlight in Simple mode and not lose max output, myself included.
Please consider allowing one to just enable the regular turbo
The code fix is very simple. I have described here:
Now I want to find the settings of the default values so that auto-lock, floor and ceiling levels are set and enabled after the reset.
Another thing to do is set the blink to any level. I want to check the optimal light level for each flashlight, the one in which there will be a constant light without the temperature regulation. A wink would indicate this level.
Turbo access in simple UI would be awesome, and I would stick with that on 9/10 of my lights.
Defaults:
autolock time: lockout-mode.h (just change the 0 to the desired autolock time in minutes)
floor/ceiling levels: these are stored in model specific cfg files. For example, KR4 defaults are in cfg-noctigon-kr4.h.
A friend of mine helped code in a smoother sunset mode to anduril 2.
His changes work for the LT1 but I’m not sure how the set_gradually feature might affect it (It probably shouldn’t)
Here’s a link Sunset mode smoothening - Google Drive
Instead of dimming by several steps once a minute, these changes cause sunset mode to dim by about 1 step at a time, once every x_seconds.
does the dimming work the same when you start out in a relatively low output level?
Gabe: I updated my Anduril 2 installation to your version, link above. Problem is it seemed to be missing the Mateminco/Astrolux FET+1 support that has SammysHP fix for the 7135 on pin #3. Just downloaded Anduril 2 to a Mateminco MT01 (same as EA01) and the 7135 channel doesn't work.
I don't know, can't recall exactly what I did, but apparently I had SammyHP's version of fsm-main.c, or had my own custom version, and lost it. Strange because I usually make a backup, but might have deleted it thinking all was working well with the first couple lights I used it on.
History on this issue:
/* S42 FET+1 driver for TA:
* Reset PB5 1 -| |- 8 VCC
* switch PB3 2 -| |- 7 PB2 Ind.LED
* 7135 PWM PB4 3 -| |- 6 PB1 Not Used
* GND 4 -| |- 5 PB0 FET PWM
Hey Tom, the thing is… My branch is a copy of TK’s, just with 1-Series support. I could probably merge SammyHP’s fix in there too though next time I’m in front of the computer. You (or someone) might need to verify it though. I have to see if I have any lights with their layout.
I just made a local change, different than Sammy's shown here: https://github.com/SammysHP/flashlight-firmware/commit/68e36b3dd3d9cb1c49b20cc218c860940cd20550
I'm not sure I understand what Sammy is exactly doing with those changes - it seems to be doing the register init. needed for pin #3 PWMing unconditionally. I prefer checking each PWM pin assignment and if any are assigned to PB4 (pin #3), then do the additional register assignments. I'll test it out soon.
Ok, just lemme know and if everything’s good I can merge it into my branch.
The issue is that the third channel is using a different port with different setup. But it’s still a two-channel driver, so there was no way to set up the output with the existing code. I simply swapped the channel setup so that the second channel sets up the output of the third channel. I didn’t invest any time to make it work with all layouts and it will work only for the different layout found in Mateminco drivers.
Unfortunately this method only gives you the resolution of the number of steps you have in your ramp.
The reason the LT1 has choppy dimming is because it uses tint-ramping which is incompatible with set_level_gradually .
I stepped up my ramp to 250 steps but the dims are still noticeable.
Thanks for the response Sunnysunsun.
Here's a link to the files for the Mateminco style drivers, or any driver using a PWM output channel on pin #3:
google drive share - Mateminco Updates
It supports 1 channel, 2 channel, or 3 channel driver configurations. I only tested with a 2 channel configuration and it worked. The cfg and hwdef files I used are included in that folder as well.
