So make your own then
86 posts / 0 new
Tom E
Tom E's picture
Last seen: 10 hours 38 min ago
To name one (set), the Sofirn C8F family of lights use a 17 mm driver with e-switch. These lights are simple, powerful, and flexible, even available as a host, as well as triple LED's and singles. I got a few of these lights - outstanding modder's platform.
The C8 popularized the 17 mm size, as well as P60's (power switch), and even bigger lights like the HD2010 (power switch also).
Quadrupel
Quadrupel's picture
Last seen: 7 hours 35 min ago
OK, ill do 17mm later … if ill get running this schematic properly at all ;))
thefreeman
thefreeman's picture
Last seen: 6 hours 4 min ago
Is there temp regulation ? Have you measured the efficiency ?
EasyB
Last seen: 11 hours 58 min ago
Looks good. Nice job Quadrupel. A boost driver with good UI is not really available before this that I know of? What are the LED currents of the modes? I’m curious is the FW based on existing FW?
Another niche that needs filling is a linear FET driver with good e-switch UI. I would buy one for my H03.
Quadrupel
Quadrupel's picture
There is overheat protection, you can set it manually, turn it on or off, but with off there is no turbo mode ;))
I have no proper tools to measure efficiency but should be much better than linear driver have anyway.
You can choose LVP level 3v; 2.5v and 2.2v
For reverse polarity using P-FET but , need to order new PCBs again with 3×3mm FET, because 2×2 is to weak. The soft is advanced , but its not open source, i can not edit it. I’m just replicating schematic with some improvement in PCB design and trying to use more powerful and cheaper components and its not so simple , because soft is coded for specific hardware and sensitive to any hardware changes; ;))
Quadrupel
Quadrupel's picture
…tada! Grad
IMG-20200819-163918
id30209
id30209's picture
Last seen: 5 hours 36 min ago
Nice!
So at the end, what are the specs?
What are the available sizes and options to order?
Thx
WTB Titanium 4sevens 2xAA tube
moderator007
moderator007's picture
Excellent job. The board looks really good, laid out well. Thumbs Up
HiTiT
Nice!
Do you have it with a single mode 20w-25w version?
Also is that possible to order a version for a magnetic e-switch?
(Hall effect sensor – basically it is a switch that is connected to ADC)
I need one for my diving light.
Quadrupel
Quadrupel's picture
Sorry, i don’t. Have no access to code, so UI as is. Its a simple e-switch .. short click , click&hold…double click…. you know. Have no idea is it works with hall sensor switch ;))
AEDe
AEDe's picture
Last seen: 1 week 3 days ago
Warning!
The author of this firmware is Tamagotchi[1] [2] , and he did not give permission for its commercial use.
Quadrupel
Quadrupel's picture
Sure, no commercial use of FW. ( Боже упаси (креститься ) DIY only Wink
Привет Фанарёвке от Stirlis (тот который послал льва и всех YLP адептов… и был забанен Big Smile )
Дрaйвер для D10 совместимый с прошивкой Tamagotchi – уже … ( шутка – гекон нервно курит в углу Evil )
Будет возможность купить драйвер без прошивки , которую сможете залить сами, через всроенный пого порт.
Boruit D10 Boost driver (in avatar) compatible with this Tamagotchi FW coming soon ! Big Smile And i can sell some drivers (hardware) without FW loaded . You can flash ATtiny85 your self, since the driver have PogoPin port Wink
Circuit and firmware link updated in first post . PogoPin Stick and 21mm PCB shared on Ospark and PCBWay.
Tamagotchi
Tamagotchi's picture
https://web.archive.org/web/20201231233223/https://budgetlightforum.com/...
Quadrupel
Quadrupel's picture
Oh, hello, can you share your latest Firmware with community, please ? Smile
AEDe
AEDe's picture
A brief history in English. This guy Quadrupel aka Stirlis(on fonarevka) systematically violated forum rules and insulted forum members. After that, it was banned. And he decided to earn extra money on other people’s developments.
I strongly recommend do not buy anything from this dishonest person.
Quadrupel
Quadrupel's picture
Not true. Tamagoshi shared FW to download for years. I made research and simplified circuit to be compatible with new generation of mosfets and diodes and made mine own PCB design.
To be honest i spend like 150$ on development and sold 4 or 5 drivers for 20$ each shipped .Id like to sell few more to get my money back . So why so jealous? Smile
AEDe
AEDe's picture
What exactly is not true?
Tamagotchi
As the author of this driver, I want to warn the forum readers that Quadrupel created this topic without my notification. Initially, he offered: “To reduce development costs, limited batch is available for sale. If interested PM .” This can be seen from the link at the web.archive.org: https://web.archive.org/web/20201231233223/https://budgetlightforum.com/...
After the ADE post, the topic author changed the first post.
I want to warn the readers of the forum that Quadrupel makes these drivers without my permission. He does not have the source code and does not able to provide technical support. The firmware and the scheme are published at the forum.fonarevka.ru, they are functional and you can build it for yourself and at your own risk, but please note that it is one of the first versions, which has been repeatedly updated later.
Once again, I want to inform you that I do not cooperate with Quadrupel and do not intend to do so in the future.
Quadrupel
Quadrupel's picture
Mr. Tamagochi I want to thank you for sharing nice FW and i will update topic soon again to share with community my 20mm and 22mm PCB layout compatible with your FW .
Don’t worry mr, i don’t need your source code to support my hardware Big Smile
Anyone can use my pcb layout and design for free with your honestly shared FW Smile
Can you share your updated FW with this nice community? Smile
BTW same PCB layout works for both 6&12V FW only you need is to change resistors R4&R7 value .
D'AVerk
Quadrupel wrote:
To be honest
You should declare the sources of FW BEFORE AEDe comment.
You should ask Tamagotchi for use FW in yours PCB design developed for selling.
Now it looks like you try to uplift some money, but have been caught on hot.
Quadrupel
Quadrupel's picture
Thanks for advise . Next time i will do so and i will contact you personally to inform how im doing Smile
And again, Mr. Tamagochi shared FW hex. file back in 25.02.2017 without any licensing and its still shared and available to download . So please , stop complaning.
clientequator
clientequator's picture
Last seen: 2 weeks 4 days ago
Quadrupel wrote:
Thanks for advise . Next time i will do so and i will contact you personally to inform how im doing Smile And again, Mr. Tamagochi shared FW hex. file back in 25.02.2017 *without any licensing* and its still shared and "available to download":http://forum.fonarevka.ru/showthread.php?t=35292 . So please , stop complaning.
Quadrupel, I thought you designed this driver because in your original post before changing it you just said you were selling it to cover development cost and did not mention any credit to original designer Tamagotchi, and worse you even make pcb with 'Quadrupel' and 'BLF' printed on the silkscreen, so you cannot say that blf members are 'complaining'. Maybe Tamagotchi did not put license, but you make it look like you designed it yourself.
This looks like original design page: http://forum.fonarevka.ru/showthread.php?t=37158
If you use his design and you make some improvement, you should at least describe in more detail. If you had permission from Tamagotchi surely blf members will still support you because not many people can read fonarevka forum. Unfortunately you still seem like you are not sorry for doing this when caught by AEDe and Tamagotchi frown
Quadrupel
Quadrupel's picture
Another crying jealous hater from fonariovka? PCB designed by me, so i named like i wanted . You can design your own PCB and name it like you wish, download firmware from link above and open own mass production.
clientequator
You may have design pcb yourself but is obvious it is a copy from Tamagotchi and the layout is similar. There is no problem in copying if you have permission and give credit, but you hide it. I am not hater and I learned about fonarevka.ru for the first time when reading about AEDe and Tamagotchi post. I am sure most people at BLF are understanding if you made mistake because everybody make mistake, but it is sad that you did not apologise. You definitely have skill so I hope you can learn from this and make some new design that everyone can enjoy.
Quadrupel
Quadrupel's picture
Its all in a name of progress!
Quadrupel
Quadrupel's picture
My last project and goal. ;))
IMG-20210216-160832
IMG-20210216-160855
Boost driver for D10-D20-D25 headlamp based on Tamagotchi’s firmware . ;))
Agro
Agro's picture
Last seen: 1 min 13 sec ago
Is it compatible with Andruil?
Quadrupel
Quadrupel's picture
Ask Toykeeper.
id30209
id30209's picture
Just a quick feedback on these drivers.
Talked with Quadrupel about getting 2 of these but to adjust them to run GT-FC40 and OP agreed it can be done and after some time it’s done. PP, shipped...
Meantime Tamagotchi chimed in and i got suspicious...
Drivers arrived, connected on Convoy M21C-U and i got crap. It can barely squeeze 1A on turbo...
Disapointed at least, not to mention poor soldering job.
Sorry Quadrupel but you should properly adjust first post with real pictures of what you’re offering.
We know you have great ideas but your execution needs to be tuned.
Quadrupel
Quadrupel's picture
“…connected on Convoy M21C-U and i got crap. It can barely squeeze 1A on turbo…”
You did what? Convoy m21c-u have 6V led . I wonder how it works at all.
