Does anyone know if and when will the mule versions be available again?
Email hank if you want mule versions.
I recently got a brass 4DV2 with 16 E21A 2000k and I love it but it behaves weird in Party Mode. Just wanted to see if others have observed similar. It flashes randomly at low to medium brightness, completely different to how my SST-20 lights behave. At first it looked like Lightning Storm to me… All the other blinkies work normally!
Any ideas why that would be?
Can you check the Anduril version of your D4v2 with E21A?
I tried flashing the D4v2.5-NoFET-2020-07-08 (Anduril 1) hex file on my D4v2 with 4x E21A, which resulted in party strobe mode that’s very dim (yup, like a very dim ‘lightning storm’ mode).
I then flashed it to anduril.2020-04-27.noctigon-kr4-nofet (Anduril 1) hex file, and party strobe mode works normally.
I’ve subsequently updated it to Anduril 2 (2020-09-27-KR4-NoFET) and party strobe mode also works normally.
(there is a newer Anduril 2 version now, which I haven’t tried).
I’m not sure if the 16x E21A will work properly with the above hex files though (since mine is the regular 4x E21A)…
Thanks d_t_a!
It has the version from 2020-07-08, so that’s the issue. Not that I really care to fix it, don’t have a flash kit and no real use for that strobe.
On another note, I know that the mules use a 7.5A driver, is that done in software or is it using different hardware?
The KR4 driver has trouble with the fast switching on that strobe mode. There is a config flag that changes the timing, but it appears to have been left off some builds.
In the Anduril 2 repository, this is around line 48 of cfg-noctigon-kr4-nofet.h:
// slow down party strobe; this driver can’t pulse for 1ms or less
// (only needed on no-FET build)
#define PARTY_STROBE_ONTIME 2
Although the comment says it’s only needed on the no-FET build, I’ve found it to be needed on my other KR4’s, too.
What is the weight of copper D4v2 with 18650 & 18350 tube (vs aluminium version)?
Has anyone heard from Hank lately? It looks like his web host is having a problem today, and I don’t see any info about it yet.
I heard from him last week, and his site seems to be working for me.
Interesting. All I can get is a banner saying “SUSPENDED”.
Just ordered a light, it’s working .
Ordered two lights from Hank today today, emailed Hank 2 days ago and got a response yesterday. Normal 24 hour response time from him as usual.
It's been like that for a while now, but the first link in the OP of this thread works fine for me.
For more information, check out the following thread:
Should we get start a petition to ask Hank to start installing lighted switches in the d4s v2? I Mean I know this has been talked about in his thread for the d4v2, but I think the d4s needs it. So it would be perfect or at least offer d4sv2 in titanium/ copper so we can get that switch
Thanks, didn’t see that thread before. I guess it’s only the front page which doesn’t work. I wonder what happened.
365nm UV, 8 pcs mule version available.
My K1 green Osram just arrived. (Green body of course). I shined it on a white wall and the spot was too bright to look at. Can’t wait to try this thing out tonight
Hmmm, UV…I still don’t have any UV.
I wonder what led it is, super curious.
I have four UV lights - all 365 nm. Very cool :). I don’t use them much these days though
