So make your own then
Which you confirmed you did...
Even worse is when Tamagotchi jumped in
Did not confirmed … I said it should be fine.
Its not fine? Oh, well… what do you expecting me to do now, specially after you wanted this tread to be closed ? ;))
BLF Rules:
BY REGISTERING AN ACCOUNT YOU ALREADY IMPLICITLY AGREED TO ABIDE BY THESE RULES:
  1. Please don't be rude. Rude people will have their accounts deleted.
  2. Please don't use dirty language, please don't swear, and please avoid lewd(link is external) or risqué(link is external) conversations.
  3. Please avoid controversial or divisive subjects such as religion and politics.
  4. Please avoid fighting. If you or somebody else is losing their calm, please drop the subject.
  5. Please don't even think about spamming this forum. Spammers will be prosecuted.
  6. Please don't even think about using this forum for illegal activities. Criminals will be prosecuted.
  7. By registering an account, you agree to the BudgetLightForum.com Privacy Policy.
  8. All opinions expressed by users of this website may or may not be accurate, and as such BudgetLightForum.com does not officially endorse them. BudgetLightForum.com does not encourage risky behavior, and will not be responsible for physical, emotional, financial or other damages resulting from the use or misuse of any information or misinformation expressed herein. All users are encouraged to use good judgement before making any physical, financial or other decisions based on the information or misinformation expressed on BudgetLightForum.com.
  9. Have fun.
BTW… found some info on FC40 “12V” led which seems to be 14V cob led.
I suggest anyone interested in dealing with Quadrupel to visit this album first.
PS you can also see driver build quality ...have fun, i’m outta here
https://imgur.com/gallery/ybHo2YE
Yes, but according to FC60 datasheet (no datasheet for fc40) it have higher 14v forward voltage than ordinary 12v XHP leds.
Yea, you wanted driver for 12V led you have it. I have no drivers for 14V led. Have a nice day .
Djozz tested it, from rngwn batch, which is who id30209 bought it from I imagine : Alibaba GT-FC40 tested (a 5000K 95CRI 12V domeless XHP70 replacement, supplied by rngwn)
11V at 1A, 11.7V at 2A, 12.1V at 3A. An XHP70.2 has a higher Vf actually.
That’s what I thought too.
This Chinese magical hi-cri led is not documented even in manufacturers website .
This all seems very shady. It’s clear the seller cannot properly customize the driver and FW. And it appears he deceived the buyer by reporting a test with a 3s LED then claiming it works for a 4s LED.
Has anyone received a working boost driver from him?
Driver works fine with 3V triple and 12V XHP leds , with 3V quad it dont work or need to be tuned.
No one have 12v version because it was made exceptionally for ID30209 only
12V XHP LEDs are 4s strings of 3V LEDs.
But have higher FV than 1 XHP ;))
Generally this is not true.
At 2A, the voltages are:
FC40 - 11.7V
XHP70 - 13V
XHP50.2 - 12.7V
XHP35 - 13.7V
4s LH351D - 12.9V
4s SST40 - 12.0V
Whereas 3s LH351D is only 9.7V.
Generally read datasheets.
Thats from FC60 datasheet, but im pretty sure its the same cause both rated same 12-14V.
Adding quotes since quadrupel seem to like to modify the posts after.
Design is completely by Tamagotchi, Quadrupel just copy and pretend that he designed it until he got caught. Even if you make your own pcb and layout (the easy part), the original design is still by Tamagotchi. He explicit stated it is not allowed for commercial use or sale without permission. If you look at schematic, the driver use Attiny85 for control of the switching regulator so it will not be compatible with Anduril or toykeeper firmware which does not have code to run switching regulator. It can be added but need a lot of work and is basically writing a new firmware. Quadrupel cannot even answer a simple question, which is expected since he did not design it.
I read the PM message between Quadrupel and id30209, and he clearly request for 12V at 1A output. Quadrupel say it can make it 'burst turbo like 30W but ill fix it on 20W for stability".
It is sad to see that you are rude to id30209. Everyone here is supportive of member trying to improve on designs and yet you do not change. id30209 clearly say he will be running a GT-FC40 led at 12V/4A, and you specifically said it will work at 12V output even if you didn't have equipment to test. You are trying to make excuse and imply id30209 is lying because FC40 is 14V led, but you are just making thing up. Clearly djozz testing show the led that id30209 is using is 12V or less at lower current. Even loneoceans lume-x1 with the same led is 12v at 2.75A, so it is clear the driver you sold to id30209 is not working at 12V or what you claim it to be.
It is a custom order by rgnwn, it looks like many people on the forum has tried it.
still trying to be snarky and mocking everyone.
You are just assuming and trying to push blame away from yourself when clearly the led is close to 12V operation at about 1 to 2A or less. Even the datasheet for fc60 show 12V at 1A. the soldering quality also look very poor, very different from the photo you post in this thread.
for id30209, maybe you can consider using other driver which are designed by actual members that work instead of ripoff. Mtnelectronic has 20mm boost driver but out of stock http://www.mtnelectronics.com/index.php?route=product/product&path=67_118&product_id=959. loneoceans lume x1 seem to work well. Convoy also seem to have 12V 2.3A single cell driver https://www.aliexpress.com/item/4000046041955.html.
clientequator is that you ?
For record
Time to be out of here as well! I hope Quadrupel can learn from this experience.
“So make your own then”
What an informative thread. Highly recommend. :+1:
It’s like coming across the scene of a few flares burning out their last ounce of fuel before going out… little bits of plastic and glass scattered about the roadway… and nothing else to see. You know something bad happened here, but there’s just not enough clues left behind to even begin to understand it. :smiley:
