RD6018 RD6018W 60V 18A power supply is published
RD6018W customer feedback
Excellent all fast delivery !!!
https://www.aliexpress.com/item/1005001488070904.html
Hello RD TECH!
I have a RD6018W and I was wondering about the maximum input voltage.
The datasheet says 70V max input, but I tried and it can take 71V.
Can I go even higher?? What would happen at 75V input (no load)??
My PSU drops 10V when under 600W load so if I would set it at 75V at no load it would be 65V under load, so I could still use the full 60V.
Please advise.
Hi friend
thank you for your support
but our limit is 70v, you can’t let it over 70V, we don’t allow
Yes you can. I’ve tested it! For everyone who is interested, there is a software limit of 72V input! It wont let you use the device above 72V.
Was that so hard to write down RD Tech?
our data is 70V , I don’t care others, we don’t allow
hello everyone, we start to work now, and we will send the orders according to the order date, please wait for your package coming
When will the RD6024 be released? We are ready for it!!!
for now we just release RD6006P, please wait
RD6018 customer review
In Russia, delivery via DPD to the halva postamat. Very comfortably. compared the readings of the voltmeter of the converter with my devices. I'm happy with the result.
RD6018W review
Finally I put together a kit. It turned out to be a nice beautiful and useful laboratory power supply for my radio workshop. The unit arrived at 65V 12.3A.(you can still get 18A output on RD6018 even it is 12.3A from the PSU)
RD6018 customer feedback
arrived quickly. packed in styrofoam. thank you seller. accuracy up to 2 decimal places.
RD6018 feedback
Good product, good seller. Detailed explanation on the YouTube channel I bought 2 of the same product. RD 6006 and RD 6018 both products are of very high quality. The product arrived quickly and is very, very well packaged.
Everything is very neat, high quality. Well done just the way it should be. It's a little silly to talk about the speed of delivery. In this case, it did not depend on the seller. Of course, I recommend it for purchase.
I collected everything for an hour. The block is whistling. To stop whistling, you need to put a resistor from the kit. In general, like everyone else, it whistles and works =)
RD6018W customer review
The original idea is a power supply from ready-made independent parts.
excellent, almost accurate readings. difference of 0.01 V relative to a verified tester.
All perfectly. The box comes with a complete set of wires and fasteners, an outlet and a switch.
all perfectly.
RD6018W feedback
The converter with the housing came to me in good condition and without any additional charges. visually everything is really good quality and it looks like everything will be OK. I am very happy with my purchase
this is necessary for everyone who works with electronics, has a pretty good monitoring, very good product.
