Good info, not sure where to get the XP-G3’s now days. Last time I bought them was back in ~2016. I never bothered ordering more as I figured something better would be around by now lol.
As far as I know, the XP-G3’s have not been getting much appreciation in flashlights due to green tint and tint shift across the beam. The same for XP-L2’s.
Maukka tested both the XP-G3 and the LH351D in a triple emitter light here. I think you should take a look:
I think the LH351D is likely your best option at this time if you want a little more overall light than SST-20’s, but it is floodier.
For maximum output, of course, you have to go for the low CRI version, but I’m not sure how the tint is on those.
Boaz has small quantities of minus green filters on offer in the want to sell thread if you want to improve overall tint. There is a slight output loss as a result.
Sounds like TexasAce wants max output. CRI is not as important for him.
I think your best bet is a light with multiple XPL Hi. Throws much further than LH351d with genarally brighter output. Still floods enough for close in use.
XPL Hi also blows the socks off SST-20. It is much brighter.
So it seems that there have not been much advancement in LED’s over the last 2 years when you boil it down is what I am getting. On one hand that makes it easier since I have experience with most of the LED’s from back there. On the other hand a bit disappointing lol.
LH351D’s are worth considering, just worried that with the extra flood they will not net me the increase in output/throw I am looking for over the SST-20.
I am assuming that good tint 3v XHP50.2’s are not a thing still as well?
I’ll pile on and say if there’s one all around champ IMO it’s the sliced 351D’s. In triples, nothing is really ‘throwy’ except 1mm² emitters like the NM1 (which is something everyone should try out btw with a 10511). SST20s are maybe 40% throwier, but unless you get the top flux bins the amp for amp throw advantage isn’t huge.
Luxeon V2s can offer good tint at lower CRI and good output I hear. KD has 3500K 80CRI 351Ds that while floody, probably pump out the lemons. XPL HI is really good too at this CRI-flux-luminance intersection. I’m not sure about 80CRI bins of Samsung emitters. 219C/319A are getting hard to find, and might not offer any advantages over an XPL, but on paper they compare okay.
BTW, contactr + SKV + the freeman, has anyone tested the FA3 K2 that MTN has or know what Richards source was?
TA, what form factor and host(s) are you trying to fill? I really have gotten away from triples and big domed emitters for EDCs because beyond a ~10° FWHM I don’t find much of a usefulness of any more ‘flood’ until it is ALL flood, ie no hotspot at all, and that’s for close up use imo, best served in a headlamp. My EDC is a FW1A with a sliced SST20 4000k (probably 600lm OTF max?) and a light pebbled 21mm TIR. I’m getting a ~10° fwhm beam with nearly no spill. This way all the lumens are there. Nothing blinding me in the periphery or foreground means I can use lower power and overall less light to get the same visibility. To be clear, it is nice to have a walloping turbo with tons of lumens for room scanning and the like, but for now there just isn’t a setup that does both well IMO while offering neutral CCTs and positive R9 in a bezel size below ~35mm.
Moving up to the D4S on the other hand is where things come together. Cd/lm and a scorching turbo all in one (larger) package.
I am using a convoy S8 host. Not sure what degree the 10511 is but I find it to be pretty much ideal in most use cases at mid power levels. Then I have turbo for times I need more light.
I would say 90% of uses are at ~500 lumens or less but having the ability to go 3000 lumens that other 10% of the time has proven more useful then I thought it would.
Worst case I can go back to the XP-G3 setup I had before assuming I can still find them. I know it gives the output and beam I want, the tint is just not as nice as other options naturally.
An XP-G3 with less tint shift and better selection of high CRI tints would be the ideal LED for me. Well within reason, just doesn’t seem to exist yet lol. Maybe the XP-G4 will prove to be it.
I would LOVE to use a boost driver but last I checked there were not any good options using BLF firmware and with the power levels I want. I would want at least 15A, 20A would be better. There were a few being developed but the projects all died last I checked.
MTN has some 80CRI 319A’s still in stock. I don’t know what tint they are but they’re D400 80CRI in both 3000 and 5000K. I’ve been tempted to try a mixed triple for a while under narrow optic. Could the hex die solve the 10507’s artifacts? IDK. Someday I might break down and find out.
I was referring to 20A input since that is what actually matters for a boost driver.
That said, yeah, I would run a 20A @ 6a output if I could, I would have to use an XHP70.2 to handle it but boy would it be fun for the 10 seconds until it got hot lol.
My vote too. I have two FW3A, the XP-L Hi and the SST-20. XP-L Hi is a ton brighter and still has a great beam minus the CRI of course. If I wanted max output from a triple with good tint and some throw that’s my pick. I’ve tried the 3A 5000k and the 4C 4500k ones.
Yeah, most forget about it but I really like it, the fins actually help more then you would think and combined with a copper spacer for the triple it can really absorb some heat on turbo before stepping down.
The 319A is a decent LED, a bit floody is the only reason I never used them much and at the time they didn’t have many good tints.
The XP-L HI was my go to LED for quite awhile until I caught the CRI bug. They are still a good LED for sure but the lack of high cri options caused me to kinda bypass them.
