Can you use just the flashlight heads and run them off of the drone’s battery pack? It would require some custom wiring etc. but you’d save some weight.
17 F of moving air is basically below freeze temperature air conditioning. Easily cold enough for hypothermia / death with extended exposure.
Yes forced air movement can make all the difference in the world. Even just a little air. Thermal energy (IE heat) traverses from hot to cold… always, never the other way around. If you can continually flow cold air over the hotter surface… it will take the heat away with it.
There is no way to tap into the battery and that would void all warranties on a drone that cost about $11,000. Thats why strapping a couple $50 lights is the sought after option.
I would try mixing floody and thrower
That is a good idea. I have tried that with handhelds and it works great.
yes this was discussed in post #16, The two diff lights weight about the same.
Nice project
I revised the design and spread the light beams apart to cover more ground. Here are the results in the video link below.
[video: Evo 2 drone lighting rev3 - YouTube]
I like the dual beam spread, thanks for the great video
personally I favor the slightly larger hotspot of the Fenix over the smaller hotspot of the Sofirn
but people often differ on their beam preferences
you may also decide to use one small tight hotspot for higher altitude, and a wider hotspot at lower altitude…
by mounting one of each you increase your options
and it still seems like you have more than enough light, which gives you the option to lower the brightness and extend runtime, while reducing heat, that may be relevant later…
all good options to have
I think you have some nice versatile beam options to use, by simply changing which lights get installed
Yes if it were not so darned cold here I would have stayed out longer and did some flying with a mixed set of 1 Fenix and 1 Sofirn in the saddle at the same time.
Yes, I personally like the Sofirn SP35 better. As mentioned above, try some D-C-Fix. Then again, you want stock lights.
+1
I’d want a super flooder light to cover as much as the field of view of the camera as possible, while keeping the lux on the ground just high enough for the camera to handle by jacking up the ISO. The hot spots are wasted light. They are blowing out the image at the lower heights at least, even with the two beams aimed apart. If you are searching the outdoors rather than just lighting up a known location, narrower hot spots are akin to searching a room using a laser pointer. Your flight pattern to fully cover a given area would take much less time if you weren’t searching with a narrow beam.
Entirely depends on the terrain though. In bush or dark green trees you need more light since less light it reflected. If you spread out the light too much it could be ineffective.
This is designed to be for sale, it needs to suit all locations, not just the snow where a lot of light is reflected.
all those movies have ‘hot spot blowout’
the light should have the same angle of even coverage, as the camera
period.
which just means you need more light or a narrower camera shot [tele/zoom]
Nice improvement with the wider spread and Sofirns greater lux/lumens I think results in a better image capture.
Note also snow is highly reflective, and most definitely does not represent the real world. You should run your tests in a wooded / shadowy area with no snow if you can. The results might change your thinking. Keep in mind this is not about what we can see… its’ about what image the onboard camera can capture.
Camera / video enthusiasts would cringe at all the digital / low light “noise” in those clips. With todays small CCD arrays and optics, this is pretty much inevitable. Low light image quality limits almost all compact, action-type cameras.
Good luck!! One things for sure, I would not want to be the guy trying to hide.
Yes, as I stated in video #1 additional tests need to be done in summer/fall with greens and browns and blacks but I live in the frozen tundra which means we wont have those conditions for a few more months. Around June I will have a very different landscape to work with.
Tir Lens beam is a cone of light, my preferred beam when using a camera
Surefire Weapons lights use TiR beams:
reflector beam has a hotspot and spill that create an overeposed hotspot, or two
A Clear TiR, designed for narrow forward focus, is by far better at producing an even field of lighting, for the way a camera sees illumination.
For camera lighting I choose this sort of beam with no hotspot (as in the Surefire above):
over this reflector beam
a few more images to show the difference between a Clear Focusing Tir, and a reflector:
Tir on left, reflector on right
Although the reflector lights being tested are working suprisingly well, despite the hotspot overexposure, and dim spill on camera. I want to mention that another advantage of an even field of illumination, is that the light can remain static longer, as the subject traverses the lighted area. With a hotspot light, there is considerably more active movement of the flashlight, to optimize the position of the hotspot and spill, as the subject moves.
Tir lenses are also more battery efficient, as they dont waste lumens on sidelighting.
Which other 18650 lights, besides the Surefire Weapons lights, offer a nice cone of light, without a hotspot? Is there an option from Fenix? (the brand has decent street cred among LEOs, outside of the more expensive, Made in USA brands such as Surefire, Malkoff and Elzetta)
If you’re careful then you could drill lots of holes in the aluminium body tubes and reduce the weight a bit. I would guess you could remove over half the body tube’s weight without it being a problem. I’ve never tried this myself but I don’t think it would affect the durability for your use case.
Just make sure to take the cell out first!
Sounds like a way to invite water.
I had the best results with aspheric optics when trying to film at night
