How do you think this light is able to get 6000 lumens out of the SBT90.2 vs other lights including K75, BLF GT90, etc which’s only able to get ~ 4600 lumens on turn on? (serious question)
I’ve owned the TS30s for over a week now, bought it on amazon us. It is a REALLY nicely made light. The best comparison I can make for its form factor- it is aAstrolux FT02s but with a 21700 specific tube. The machining and quality are fantastic for the price. It’s almost the same exact size as a ft02s, but with that smaller battery tube which is nice. It compares in output to my Lumintop X9L but throws further. Definitely middle ground between lumintop x9L and astrolux ft03s. This ta30s is one of my favorite lights recently. I only have one negative about it, is there is a prominent outer ring in the beam outside. Any not bother some people.
Yes, I also love it. It’s more compact than the FT03S for everyday carry. If I need a long throw, I choose TS30S if I need to throw a shot, I will bring the FT02S
a) software bug in the UI of your sample - can you please try following?
remove battery
hold side switch for 5s
insert battery again
try activating the aux light (7C from OFF, 3C from lockout)
If that does not work, please perform a factory reset of your light:
option 1: Loosen tailcap, hold side switch + tighten tailcap, keep holding side switch for 3s
option 2: 13H from OFF (click thirteen times but hold the last click)
b) hardware defect - the aux LED cannot light up
I wonder if the charging LED is different from the standard aux LED or is it the same? During charging there should be red/orange light but when finished it should turn green. Does the switch of your sample light up green when charging is completed?
