✌ ASTROLUX K2 300lm Keychain USB-C Flashlight
Ordered one in white 4000k. Thanks!
But I find it a bit weird that on the other colors the side LEDs just shine through the colored body. And in the video it looks like it doesn’t work very well. If that wasn’t the case I would have taken a colored one, I think they look pretty cool.
Interested thanks
:cry: :cry: :cry:
Battery issue?
I also noticed this, but it looks like one of the colored versions is brighter, maybe the blue with stars ?
@ freeme, can you help us :question: i still don’t know what to pick as my second light
Ordered 2, thanks freeme
Interested.
Side LEDs should be identical for all shell colors.
Ordered one purple 4000k. Thanks Freeme!
Interested
Possibly.
Huh? It says right in the Banggood listing:
“2. Because of shells with different color, light colors of sidelight may be a little different”
That is correct. I have not seen the actual product yet, but I am quite sure that will be some color shift for colored models. For example, red LED output projected through starry blue shell will give slight purplish tint to it (to be confirmed).
Can you explain the operation UI . I don’t quite understand.
“Operation (machine translated)
In the operation logic shutdown mode,
Click to return to the stepless dimming memory position. Long press to enter the stepless dimming. Default minimum brightness. Long press until extremely bright.”
I long press to turn in on/off? Then let go and press again to adjust brightness? Or is it single click to turn on/off and it starts from last brightness level.
This ^ +
Long click from OFF to start ramping from the lowest setting.
Then, from ON (and even from OFF), there are other options to access Turbo, Strobe and the other Leds.
Oh if that’s the case then I don’t think I’m interested, for a keychain light that sounds like a lot of accidental on/offs when it’s in the pocket/purse with single click on/offs.
Interested
isn’t that what lockout mode is for :question:
if i don’t lockout my fw3a it would turn on 20 times a day
Final.
Order placed for 2. Thank you!
