I can also reflow them onto a board if you need. PM inbound.
How ya goin? I’d like to order 2 of each, please. Also, what do you charge for your reflow services? Thanks!
pm
Hello,
I would like to purchase 20 of SW45K.
Thanks.
Sure thing. PM incoming
Hey, do you have 10 sw45k left?
Shipping to Germany
Yes those are still available. Only the sw30 is almost out of stock. PM inbound.
UPDATE: sw30 is now SOLD OUT
I have a Nitecore MT06MD and it’s literature indicates it has a 90+ CRI 5000 kelvin 219B emitter…
Does the 219B exist in a sw50k? I’m assuming that would be a 5k colour temperature?
Googling that part number nets me zero results.
I must not be understanding something correctly.
What does the “L2” part of the part number mean?
The datasheet for the r9080 doesn’t show any 5000k CCT so it’s likely your emitter is not r9080. Might be r9050.
L2 is the forward voltage bin at 700mA:
L1 is 2.7v - 2.9v
L2 is 2.9v - 3.1v
M1 is 3.1v - 3.3v
Even googling [nichia “sw50k”] without the r9080 literally shows zero results. Is it possible Nitecore just used a 4500k LED but advertised it as 5000k?
Looks like I have some more reading to do, have no idea if I need L1, L2, or M1.
Is forward voltage just the minimum startup voltage for the diode?
Yeah if it did exist, it was a really long time ago. I know Nichia used to have the sw45 but then it got discontinued in favor of the sw45k.
All of my emitters are L2 so I’m not sure how easy it is to find L1 or M1.
ilikelights: azhu:The datasheet for the r9080 doesn’t show any 5000k CCT so it’s likely your emitter is not r9080. Might be r9050.
L1 is 2.7v - 2.9v
L2 is 2.9v - 3.1v
M1 is 3.1v - 3.3vEven googling [nichia “sw50k”] without the r9080 literally shows zero results. Is it possible Nitecore just used a 4500k LED but advertised it as 5000k?
Will you have enough of the sw45k 9080 left over by the time I read up on and learn about forward voltage and binning? I’m probably looking at picking up 5 of them.
Nitecore LA10 CRI uses 219b 5000k too.
Tell me how I know… I needed it to compliment my MT06MD.
azhu: ilikelights: azhu:The datasheet for the r9080 doesn’t show any 5000k CCT so it’s likely your emitter is not r9080. Might be r9050.
L1 is 2.7v - 2.9v
L2 is 2.9v - 3.1v
MoreLumens:Nitecore LA10 CRI uses 219b 5000k too.
Yes I have enough sw45k for you
Hey, can I get 10 sw40 please? Thanks!
You got it. PM inbound
The first Astrolux S41 was 219b 5000k. Then they started putting 219c in them.
Maukka measurements are available here:
https://budgetlightforum.com/t/-/40023
Ordered from Azhu on the 22nd Feb, posted through my UK-based letterbox on 27th! That’s service, thanks
Appreciate the specific model numbers being included with the LEDs too so there’s not doubt as to what they are.
Just need to get my reflow hat on…
Hi, looking for 20x sw45k shipped to CA
PM inbound
