With regular switch i cannot enter config menu. I tried to measure the current and got a max reading of about 4 amps.
In that case it seems some of off-time memory components are damaged (3 o'clock, capacitor,resistor,diode).
Doh! Must be my shitty soldering skills… again
Worth checking that there’s no solder linking the via for the negative LED cable with the outer ring.
(Also, not sure what would happen if the positive via is connected to the centre spring pad. )
Neven,
I hope you are doing well with the earthquake and all. Any update on when the shop might open? Thanks.
I hope within 10 days.
Thank you for the update. All the best to you and yours.
Neven, I hope you are well!
I’ve been thinking about one thing regarding your drivers. I am not sure if it would be feasible or even desirable, but I’d like to ask your perspective about it.
Looking to the Mode Groups your drivers have, would it be - again - feasible or desirable to add 1 or 2 more options, in which the max wasn’t 100% ?
- adding an option for 50%
- adding an option for - let’s say - 5% - 50% (or some more “logic” percentage, in terms of programming or visual perception of light, etc.)
As example, the option 3 of the menu is *9% - 100*. But knowing that the 100 can also be achieved (in any option) through double or triple clicks (if configured that way), it could be nice to have something intermediate so that we could run the lights without being on max (550% or 5% 60 …I’m not the best for percentages I confess).
The other options would stay the same of course, it would be just adding some more possibilities of mode groups.
Don’t know what you think of this, but I’d be glad to learn about it!
Thanks in advance!
Picking modes will not be a problem with next driver(s) iteration.
Thank you for your reply and that is nice to know
Will be looking for them :+1:
Awesome! Thx Neven
:+1: Having more control over the precise current of your modes is good, makes the light more versatile. FWs nowadays like Anduril are very customizable, but it’s not really possible to precisely customize modes in the UI. For example, if I want a 3A mode and a 1.5A mode you can sort of trick Anduril into giving you that, but that’s not really in its functionality. That’s why I really like convoy’s configurable linear driver. I hope your drivers have some of this unique functionality and work with eswitch.
Any updates on the store opening?
10 work days, so next week.
Randomly decided to check your site and got worried when it didn’t load.
I was thinking I should order parts to upgrade my c8f to 6x and Samsung LEDs.
The site is back up! I placed a little order. Thanks for offering these products Neven!
Q8 5050 Led projects must be canceled
:cry: :cry: :cry:
I want to order some goodies for my 21700 C8F from Sofirn and I think the “C8” parts will work but I don’t know which driver or if I even need a different driver.
Figured I’d also get a bare 4040 board so I could compare the SST to LH351d.
Also, where are people sourcing the Anna optics? I’ve bought and used quite a few Ledil products but they’re always difficult to source.
You don’t need different driver as long as it’s 3v. However I’d recommend MCPCB without FET on it: led4power
Anna optic is available as an option for €3.50 (checkboox above “add to cart” button).
SST-20 and LH351 require 3535 board, not 4040.
Wow. How did I miss the checkbox?
The page for the 4040 board lists the LH351… I thought it was “3535” size like you…
…though, I’d probably prefer an Anna W (30deg) or WW (65deg)
